Old 01-23-2011, 01:02 PM
miketeachesclass miketeachesclass is offline
Default Rackmount PC as opposed to Laptop for portable rig
Is anyone using a rackmount PC instead of laptop for their portable rig?
I'm sick of all the problems that come with PC laptops, and was thinking of putting my desktop in a rackmount case for use with my portable rig. Yes, it's a bit of a pain for ultra portable gigs, but I figure I've still got the laptop for things with really low track counts/requirements.
Any opinions?
Old 01-23-2011, 01:36 PM
sunburst79 sunburst79 is offline
Default Re: Rackmount PC as opposed to Laptop for portable rig
I like rack cases.
It mostly depends on your tracking and mixing needs but as long as you can deal with the luggiblity factor the Rack PC is going to be about 10 times more powerful than a high end PC or Mac Laptop for the same amount of money or less. If your already lugging a rack of pres to the gigs its not that much of a deal to drag another rack.
Or you may find that its the straw that breaks the camels back.
Permanently mounted in a studio its a no brainer.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-23-2011, 03:11 PM
Hercules Hercules is offline
Agree with sunburst79 - racks are great, but two words of caution :
1/ racks get heavy so be careful if you're moving it
2/ roadies are not the most careful creatures.......
Old 01-23-2011, 03:19 PM
Its true.
Moving my PC/001/D8/D8/Power Strip/etc 12 space rack is not a one man job. Splitting it into a couple of 4-6 spaces would be more managable.
However all I currently have do is unroll the snake and find a power outlet
Something to keep in mind is most rack cases are deeper than standard racks. So you want to lock at depth measurements closely.
Scott
Core 2 Specs Page
Old 01-23-2011, 03:59 PM
mykhal c's Avatar
mykhal c mykhal c is offline
travel with a cloned OS hdd...not mounted in case
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 01-23-2011, 05:00 PM
Originally Posted by sunburst79 View Post
Its true.
You're not kidding. I can't find a case that's shallow enough to fit in a normal rack. What case are you using? And what rack are you using? Any suggestions?
Old 01-23-2011, 06:12 PM
The rack is a 12 or 14 space Road Ready rack with room to mount a angled mixer in the top compartment. As I recall the rack case is a ARK 500 from New Egg. I can look and see if your interested.
Fit...In order to get it to fit I had to find a 90 degree electrical cord. But it does fit.
According to New Egg it should be this
The Road Ready case is one like this
Scott
Core 2 Specs Page
Old 01-24-2011, 09:03 AM
Thanks a lot!
Looks like a pretty good solution.
Do you think it would be necessary to use a shock mounted rack for this, or is being pretty careful while moving it enough?
Old 01-24-2011, 09:54 AM
Thanks a lot!
Unless you literally throwing it into the back of a truck it should be fine. You don't need the slant top rack by anymeans either. I just posted it to link to the dimensions. A standard rack would most likely lighter than a slant mount one.
Scott
Core 2 Specs Page
Portable Laptop Studio. Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-13-2009 03:00 PM
Portable Laptop LE Solution For HD TDM Guys hearttimes Pro Tools TDM Systems (Mac) 2 01-25-2008 08:58 PM
Portable HD rig - Should I use 002 and laptop? andre1 Pro Tools TDM Systems (Mac) 0 07-01-2004 01:52 PM
Any advantages to OSX10.2.8 as opposed to 10.2.7 develo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-04-2003 11:15 PM
portable laptop tracking quintheskimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-15-2002 04:49 PM
