LLM I've tested 3 differents system and still
About LLM is a little longer I try make it shorter
PT 9.0.1 – 9.0. 003 Rack+ Channels : Analog I/O 1. LLM works fine 2. If select LLM loose the audio (you can rec but stop monitoring )when deselect LLM audio is back 3. When select LLM, there is audio, but does not work on latency 4-8 the same as 3 ADAT I/O 1-8 LLM not working(audio is present ) 8.0- 8.0.3- 8.0.4 003 Rack+ Analog. Channels :Analog I/O 1. If select LLM works fine 2. Select LLM does not work but you have audio( difference from 9.0-9.0.1) 3-8 LLM does not work but you have audio. ADAT I/O 1-8 Not LLM but audio is present MBOX 2 PRO Channels i/O 1-2 LLM works fine 3-6 LLM doesn't work (there is audio always) So it happen whith computers system that always worked before. Details : 1- GA-X58A-UD3R I7 950 Asus En 7200GS Video card 8 GB Mushkin (3x2) Win 7 64 bits PT 9.0.1 DIGI 003+Factory ADA 8000 2- ASUS P5B Q 6600 3GB ram Firewire Card SIIG PT 9.0.1 Win 7 64 Bits DIGI 003+Factory 3- HP NW 9440 MBOX 2 PRO 3GB Ram WIN 7/ 64 8.0.4/// PT 9 Laptop HP NW 9440 recommended and supported by Avid(Digidesign). All of this was done whithout any additional plugins only PT soft. Avid guys says: ” This is a known issue and is in the queue for a fix. "The problem is that only Audio tracks are working with LLM - Instrument and Aux tracks do not.” Also in Audio tracks . “ We've got this logged for a fix. I also posted in the other thread about this issue.” Avid Audio Tech Support. One last thing Latency is major on Adat I/O than analog, this new too in my system as long I can remember. Someone else?
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Re: LLM I've tested 3 differents system and still
To people whith more experience, a question thanks for an answer.
What really does LLM?,(besides Bypass plugins insert) reduce manually the buffer? whithout change performance or do something different?
It's supposed to route audio from the analog inputs through a built-in hardware mixer and back out the analog outputs. In LLM, audio from the inputs never actually goes through Pro Tools. It goes into it to be recorded, and at the same time it goes right back out through the built-in mixer in the interface. That's how it achieves such low latency, and it's why plugins and sends on the tracks being recorded don't work - the audio is not actually going through them. The levels of the hardware mixer are controlled by the faders in Pro Tools. I don't know whether or not it's supposed to work with digital inputs and outputs.
With the computers you listed, there should be no need to use LLM. Set your hardware buffer to the lowest available setting. You won't notice any latency on analog inputs for sure. Don't know about the digital ones.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Really Thanks.
I realized that LLM it seems only for 1-2 analog outputs, what I dont understand is why when I set 1 and 2 analog ouputs (independent)one of the other and apply LLM the out 2 stop the audio but meters read on the screen then LLM off audio is back, is that right? should monitoring 1-2 always as a stereo tracks, not 1- 2 monos independents I can work even in 64 buffer quite well Am I loosing some or is a bug
The problem with the audio stopping is the bug that they're working on. The workaround is to not use LLM. It doesn't really help anyway unless your computer is so old that you can't use a low hardware buffer setting. Not one person in 1000 can hear the difference, and without LLM you get to use plug-ins and reverb during tracking.
So is a real bug!!!
and is right then that LLM works only for analog outs 1-2 ??? HOPE THE FIX WORKS FOR WIN AND MAC I haven't see more people in WIN as far i remember.
ISCSI, Has anyone tested it with PT? | mozart | Pro Tools TDM Systems (Mac) | 6 | 05-19-2010 03:18 PM |
New mac pro tested... | blackpoetry | Pro Tools TDM Systems (Mac) | 18 | 10-19-2009 01:42 PM |
OS 10.4.4 is not tested or supported...yet. | DigiTechSupt | Pro Tools TDM Systems (Mac) | 20 | 02-14-2006 11:19 PM |
"Not Tested or Recommended with PT 6.7"...how bad? | GT40sc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-18-2005 08:27 AM |
Anyone tested PT 6.0.2 for 002 yet? | Enrico Donner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-03-2003 01:20 PM |
