PT9 White Noise Bursts Killing Me!!!
Running Pro Tools 9.0.0 with MBox and can't get rid of random bursts of white noise that will eventually lead to distortion on all audio output and require closing of program to fix. Have virtually no inserts/plug-ins active and only around 12 channels of audio so shouldn't be taxing system at all. Have researched forum but cannot find anything that will correct it. Specs are below and any insight would be GREATLY appreciated.
Thanks in advance, TMM Sony Vaio i7 Q740 6 gigs ram Windows Home Premium 64 bit LaCie 500g 7200 external HD (running firewire 400...have tried usb 2.0 and e-sata with no change in problem) Nvidia Geforce GT 425M video card Pro Tools 9.0.0 w/Mbox mini |
Re: PT9 White Noise Bursts Killing Me!!!
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
sorry, here is:
SiSoftware Sandra Computer Model : Sony VPCF136FM Workgroup : WORKGROUP Host Name : Variable-VAIO User : TMM Processor Model : Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz Speed : 1.86GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Sony VAIO BIOS : AMI R0180Y9 09/03/2010 Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DDR3 SO-DIMM Chipset Model : Sony Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Sony Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.13GHz (4.26GHz) Total Memory : 6GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : Samsung M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Elpida EBJ21UE8BFU0-DJ-F 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (10-10-10-27 5-37-11-6) Video System Video Adapter : NVIDIA GeForce GT 425M (64 SM5.0 1.12GHz, 1GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GT 425M (64SP 2C 1.12GHz, 993.4MB) CUDA Processor : NVIDIA GeForce GT 425M (64SP 2C 1.12GHz, 993.4MB) Compute Shader Processor : NVIDIA GeForce GT 425M (64SP 1.12GHz, 993.4MB) Storage Devices SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 596GB (C:) LaCie d2 quadra 500.1GB (FireWire/1394, NCQ) : 466GB (D:) HL-DT-ST BDDVDRW CT30N (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices System Reserved : 100MB (NTFS) LaCie (D:) : 466GB (NTFS) @ LaCie d2 quadra 500.1GB (FireWire/1394, NCQ) Hard Disk (C:) : 586GB (NTFS) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Recovery : 10GB (NTFS) Hard Disk (Q:) : N/A Optical Drive (E:) : N/A @ HL-DT-ST BDDVDRW CT30N (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Sony PM55 LPC Interface Controller Audio Device : Sony P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : Sony 0BEAh Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Disk Controller : Sony P55/PM55/3400 6 port SATA AHCI Controller Disk Controller : Sony PCIe SD/MMC Host Controller Disk Controller : Sony PCIe SD/MMC Host Controller USB Controller 1 : Sony P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Sony P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 3 : Sony uPD720200 USB 3.0 Controller FireWire/1394 Controller 1 : Sony E832h SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : EPSON NX410 Series (360x360, USB, Colour) Network Services Network Adapter : Marvell Yukon 88E8057 PCI-E Gigabit Ethernet Controller Network Adapter : Intel(R) Centrino(R) WiMAX 6250 Wireless Adapter 1 : Intel(R) Centrino(R) Advanced-N 6250 AGN (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 |
You're network cards are turned on. Net cards dont work with Pro Tools.
You have different memory modules, this can cause problems. You'll need to set the timings in your BIOS? Or try ripping out one of the ram sticks to see if it helps with white noise. Mike.
thx mike, i will try the easier network card disable first before tackling the bios timing settings and/or removing ram. have work travel for a week but will get back with results. again your help is much appreciated.
tmartin |
Also, just to be sure, you're not recording to the operating drive are you? I see the lacie listed but are you using it every time?
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Something else that makes me curious; I see mismatched RAM sticks. I would try removing the smaller stick and retest. +1 for disabling wifi when running PT. Its also possible that the firewire controller is not PT compatible
thx to everyone for the insights. i have removed the mismatching ram and disabled all network adapters but still have the white noise and distortion issue, though it seems to take longer to start, and if i reduce the master fader to nearly off, the signal is clean...could this be a problem with the mbox mini? i have copied the latest sandie below; any further assistance from you all is SO WELCOME. thanks again.
SiSoftware Sandra Computer Model : Sony VPCF136FM Workgroup : WORKGROUP Host Name : Variable-VAIO User : TMM Processor Model : Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz Speed : 1.86GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Sony VAIO BIOS : AMI R0180Y9 09/03/2010 Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR3 SO-DIMM Chipset Model : Sony Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Sony Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.13GHz (4.26GHz) Total Memory : 4GB DDR3 SO-DIMM Channels : 1 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : Samsung M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : NVIDIA GeForce GT 425M (64 SM5.0 1.12GHz, 1GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GT 425M (64SP 2C 1.12GHz, 993.4MB) CUDA Processor : NVIDIA GeForce GT 425M (64SP 2C 1.12GHz, 993.4MB) Compute Shader Processor : NVIDIA GeForce GT 425M (64SP 1.12GHz, 993.4MB) Storage Devices SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 596GB (C:) LaCie d2 quadra 500.1GB (FireWire/1394, NCQ) : 466GB (D:) HL-DT-ST BDDVDRW CT30N (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices System Reserved : 100MB (NTFS) LaCie (D:) : 466GB (NTFS) @ LaCie d2 quadra 500.1GB (FireWire/1394, NCQ) Hard Disk (C:) : 586GB (NTFS) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Recovery : 10GB (NTFS) Hard Disk (Q:) : N/A Optical Drive (E:) : N/A @ HL-DT-ST BDDVDRW CT30N (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Sony PM55 LPC Interface Controller Audio Device : Sony P55/PM55/3400 High Definition Audio Audio Device : Sony 0BEAh Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Disk Controller : Sony P55/PM55/3400 6 port SATA AHCI Controller Disk Controller : Sony PCIe SD/MMC Host Controller Disk Controller : Sony PCIe SD/MMC Host Controller USB Controller 1 : Sony P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Sony P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 3 : Sony uPD720200 USB 3.0 Controller FireWire/1394 Controller 1 : Sony E832h SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : EPSON NX410 Series (360x360, USB, Colour) Network Services Power Management Mains (AC) Line Status : On-Line Battery No 1 : 57% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 |
oh, and always using the lacie for audio btw...
tried using usb 2.0 and e-sata since removing mismatching ram and disabling network adapters. digital distortion and white noise still returns after using for a short time. i am getting to my wit's end. read the thread "PT 9 and Windows 7 major CPU spike fix!! PT 9 bug, with fix" from the will the weirdo and i guess i'll delve into that next. majorly frustrating as i have a project i cut in nashville last month and need to finish at home but can't get bug free. once again any help or insight from the group would be greatly appreciated.
White noise bursts | gemada | Pro Tools SE and Essential (Win) | 6 | 06-20-2011 12:51 PM |
PT9 White Noise Bursts | therecordinghouse | Pro Tools 9 | 1 | 11-19-2010 10:12 AM |
White Noise Bursts in PT9 | mattytoldhatty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-15-2010 05:35 PM |
white noise bursts | deedpartle | Pro Tools TDM Systems (Mac) | 9 | 08-26-2009 04:22 AM |
Bursts of white noise | Danielle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 01-24-2004 06:30 AM |
