Mbox2 as sound device in Windows 7
Hello!
I just got my mbox 2 and want to use it as my main sound card as the internal soundcard in my acer is very bad! I have fiddled around in sound settings but I just can't do it. Can anyone help please? :) |
Re: Mbox2 as sound device in Windows 7
Post a Sandra report on your computer and tell us what version of PT you intend to run and the OS on which you intend to run it.
You should be able to switch off your onboard one within device manager.
Depending on your OS and PT version, there are certain limitations to what a Digi interface can do. Post the information I asked for above.
I am not sure if I have all the information
My OS: Windows 7 64-bit home edition Protools version: Mbox 2. I installed the software that came with the hardware first. Then I upgraded to 8.0.3. And then I updated to Pro Tools LE 8.0.3 Cs2. |
Shouldn't it be simple as that? I also run Win 7, when the mbox is connected, all sounds go through it, when not connected, all sounds go through the onboard sound card, no need to disable anything.. Did you install the appropriate audio drivers? http://avid.custkb.com/avid/app/self...p?DocId=362875
Thanks!mNow I managed to find the device. But there is still a problem. The sound sounds like a robot singing. And its not pleasent for the ear. How do I fix this?
Did you find a solution?
I´m having the same problem. Win 7 64-bit Ultimate. |
No, I haven't done anything musical for a bout a month because I am getting some studies out of the way. I think that you may need to get the latest asio driver and configure it when you open an application that will trigger it to start.
I will have another go in a couple of weeks once I have finished my studies. Let me know if you have any results. |
hey i had the same problem
but i found a solution what you need to do is install the latest ASIO4ALL drivers from "http://www.asio4all.com/" download and install during the installation MAKE SURE YOU TICK OFF-LINE SETTINGS after the installation is complete goto start menu and goto the ASIO4ALL program offline Settings You should now be able to see your original sound card and Digidesign Mbox 2 Audio there. Click the "On" button which then becomes blue Press the drop down box and make sure the Mbox2 out 1/2 Out is turned on now you can close ASIO4ALL Now goto Control panel and Hardware and Sound, and choose Sound once that opens up make sure you are in the Playback tab and you should now be able to see: Line 1/2 Digidesign Mbox 2 Audio and then set that to Default device and you are done NOTE: this was done on Windows 7 Ultimate 64 bit |
MBox2 - USB / Windows problem - USB device not recognized / DIM lights | galwanoskop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-22-2012 12:56 AM |
I want to use my 96io as my regular windows 7 sound device. | Neily | Windows | 3 | 12-17-2011 02:27 PM |
Using MBox 2 as Sound Device in Windows Vista | jwlitster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2010 08:02 PM |
Mbox2 Windows audio issue- no device found | jawhelan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 09-09-2008 07:34 PM |
Need help-- Mbox2 Mini in Windows: "No Audio Device" | DontLetMeDrown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-19-2007 12:06 PM |
