D24+MIX Farm in Magma 2 slot question
I have a Magma CB2 and a d24 with a Mix Farm. The system works if I have the d24 in the first slot, and the farm in the second slot., however it will not pass signal from an interface on the farm card. I have read that the proper card order is Mix farm and then d24, but if I do this, it doen't recognize the d24 card and fails to create a DAE Deck. Any suggestions? Is this a d24 card rev. issue? Let me know. Thanks.
-Evan |
Re: D24+MIX Farm in Magma 2 slot question
top
Anyone?
It could be a rev issue. You can verify by locating the letter printed in the lowest oval (there are 3 of them) to the left of the plastic receptacle on the middle/top of the board. Rev G or earlier will require an upgrade ($50). Rev G1 adds compatibility with G4's and newer chassis. If you need an upgrade, please call tech support to setup an RA.
If the card is already G1 or higher, please list which CPU, OS, and interfaces you're using. -Jordan |
Magma 2/4 slot question | lumpo | Pro Tools TDM Systems (Mac) | 9 | 06-30-2003 11:00 PM |
Magma 4 slot user question | JamerJ | Pro Tools TDM Systems (Mac) | 0 | 07-04-2002 12:37 AM |
Slot Order for PTHD5.3.1 + AV Option 5.3.1 + Magma Chassis 13-Slot + PowerMac G4 AGP | Samhein | Pro Tools TDM Systems (Mac) | 1 | 06-27-2002 11:39 AM |
Help! - Magma 4-Slot w/Mix+ Setup Question | rtcstudio | Pro Tools TDM Systems (Mac) | 8 | 03-27-2002 10:46 PM |
Crappy sound of the magma 2 slot chassis question | Tex Tiles | Pro Tools TDM Systems (Mac) | 2 | 03-08-2002 10:39 AM |
