AAE Error -20026
Hi people,
It's been a while... Belated Happy New Year wishes to all! I get AAE error -20026 whenever I open a particular session. It doesn't seem to cause any problems, and the session works as expected after closing the error message. All my searches have yielded zero results. Does anyone know this error and what causes it? Thanks.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Re: AAE Error -20026
I Googled it and found this:
“It's an iZotope RX error – usually happens when you have saved the session with the iZotope window open. It is safe to ignore and I believe iZotope is aware of the issue.” |
Thanks for the quick response! It does seem harmless, and maybe copying everything into a new session will make it go away. For now it always shows when I open the session. Strange, though, I don't remember using RX anywhere in this session.
I only use Izotope as AudioSuite, but have noticed the display getting “laggy” if I even leave the AS window open. Mac and Windows both.
I checked the tracks one by one, and there was no sign of RX usage anywhere. There are probably other causes for that error message. I eventually got rid of it by importing the tracks into a fresh session. It's all good now.
AAE error -20026 | sleiweke | Pro Tools | 6 | 11-16-2022 03:05 PM |
AAE Error 20026 was encountered. | henningaround | macOS | 7 | 05-23-2019 12:34 AM |
AAE Error -20026 | ulisauer | Windows | 1 | 02-21-2018 07:12 AM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
