Working with an HD session in LE?
Hi guys,
I was in a studio at the weekend working on an HD3 accel G5 system. I now want to move the sessions into an LE mbox1 system on a PC to mix and possibly do bit more recording. The PC is an opteron 165 clocked to 3GHz with 2GB RAM. The sessions were not particularly huge, 15 - 20 tracks and the producer did a basic mix with some plug ins added. I want to know what are my chances of being able to work with the sessions, I realise there might be some special plugins used in the session that I don't have, but what of th standard HD plugins? Will LE be compatible with them? Will the session even play? Advice please!
MacBook Pro C2D 15" 2.33GHz + 2GB RAM + 160GB Mac OS X 10.4.8 Mbox1 + Pro Tools LE 7.3 LaCie 160Gb External FW800 HD Alesis M1 Active MkII |
Re: Working with an HD session in LE?
And as far as I can see the restrictions for LE and M-Powered systems are exceeding voices will be set to OFF. And obviously plug ins you don't have won't work, but that has nothing to do with the system you're using. Hope this helps, Timothy |
Thanks for the reply, thats great news. Do you know if the standard digidesign plugins that were used in the HD session map to the standard rtas digi plugins in LE? Or would they all just be deactivated when opening in LE?
Hmmmm?
Sorry, I don't know. I'd assume they work - but then again, who knows. Just give it a try. All the best, Timothy |
Certainly will! Thanks for your help.
Rich.
dissapearing act (session working on?) | basslik | macOS | 0 | 12-18-2011 12:07 PM |
Working in session and PT just closes!!! | alw4416 | Pro Tools TDM Systems (Mac) | 14 | 01-13-2008 10:04 PM |
plugin's not working on HD from 002 session | studiojimi | Pro Tools TDM Systems (Mac) | 0 | 12-18-2006 12:44 AM |
Working with an HD session in LE? | nero120 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-17-2006 06:27 AM |
multiple PT stations working on the same session | tsd | Pro Tools TDM Systems (Mac) | 3 | 10-20-2006 04:32 PM |
