Old 01-08-2021, 01:51 PM
2crows 2crows is offline
Default Re: carbon hardware setting in PT
thx , i will look into this , cant at the moment but will asap
Old 01-09-2021, 01:14 PM
you were right , it was unattenuated, main was selected, i appreciate everyones time, im glad i brought it to you guys, hopefully i can be a help in the future,
cheers
Old 01-11-2021, 11:48 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
If Main is selected, then MON L-R outputs would be attenuated. To clarify, is that the case and you're still getting very loud noise when using the "Test" button in AMS? Or, is that test noise now being emitted at a normal volume?
And, does monitoring control seem to be working ok in Pro Tools as well as other applications?
Thanks.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 01-11-2021, 12:04 PM
The problem, user , occurs when i had protools "aggregate" selected instead of "reserved for protools selected in audio midi setup, entirely my fault
File Type: jpg Screen Shot 2021-01-11 at 2.59.00 PM.jpg (52.7 KB, 0 views)
Old 01-11-2021, 12:14 PM
Ahh, I see. If you do need to aggregate Carbon with another device, then only aggregate the "I/O" device and not the "Reserved..." device as shown in your screenshot. The "Reserved..." device should only be used by itself in Pro Tools. That said, we didn't test aggregation of the "I/O" device much so your experience may vary.
Hope that helps.
Kyle Splittgerber
Berkeley, CA
Old 01-11-2021, 01:46 PM
yes it does ,
i am taking the PT certification course, is there a source for instructions on how to use the available plugins, i am a musician first at this point, i want to be able to at least record and use plugins, i have tracks set up to record , no prob , i know all this will be covered later ,I am 1/4 through the first course,
thank you
Old 01-11-2021, 03:20 PM
yes it does ,
thank you
Sure. You can find the Carbon guide here. Pro Tools setup is covered on pages 18-24 (sounds like you've got that going though). And, DSP Mode (using DSP plugins and recording) is covered pages on 25-35.
Additionally, there are a number of helpful videos here. For recording and using DSP plugins, I'd focus on these:
Introducing Hybrid Engine
Recording Basics
Advanced Workflows
Kyle Splittgerber
Berkeley, CA
Setting up Hardware Inserts amathie Pro Tools 12 19 11-10-2016 11:36 AM
Setting up Different Hardware Profiles Allen Hallada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-22-2003 01:12 PM
hardware buffer setting in cubase sx Da Gatekeepa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-30-2002 08:13 PM
hardware setting error doyle204 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2002 02:59 PM
