Linking channel mutes
On an SC48 I am double assigning 8 channels so that I can use the second set for the monitor feeds. Is there a way to link the channel mutes to its monitor mate? Sometimes the monitor channels are on a lower layer and I would like to be able to mute individual channels but have it also mute its mate. I don’t want to have to do this with the mute group buttons and I don’t want to use up all of the mute groups. I want a channel link function but where only the mutes are linked. Is this capability available and I just haven’t found it yet?
Re: Linking channel mutes
you can make an event in the option page. make as trigger mute channel (foh), action mute channel paired (mon).
what normaly do for almost every show or festival, where i don't know exactly what is comming: 8 vocals channels, doubble assign the inputs (just as you described). and create an event where the foh fader is down mon channel mutes. and where foh fader is little bit open, monitor channel unmutes. works great! |
This is in a church and any of the 8 vocal mics that are double assigned may need to be muted individually at any time.
The event solution sounds like it will do exactly what I am looking for. Thank you. |
When I set it as follows it works in one direction. Triggers CH1, Mute channel, on CH1, Mute channel, off Action Mute CH33, Toggle, While Active, Wait 0.0sec Am I doing it correctly? |
Change the modifier to "XOR" instead of "OR" or "AND"
Change "While Active" to "Toggle" That should work for you.
Ken Miller, Jr. Audio Engineer Southside Baptist Church | Warner Robins, GA | VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
It looks like there isn’t way to link the functionality of the buttons together and have it behave properly. Or should I say behave the way I want it to. Which is basically they both perform the same function and mute and un-mute each other. I have found a way to configure it that I think will work well for the client based on their needs. Based or what vickingthor suggested. I have set it up so when the FOH fader is down (below –90) it mutes the MON channel and when the FOH fader is up (above –89) in un-mutes the MON channel. And I have it set so if you mute or un-mute the FOH channel it mutes and un-mutes the MON channel. I think this will work for them and the behavior is very logical. Now the question is how many events can I program into the SC48? If I am right I will need the 3 events per channel (8 for this functionality) that I want to act this way. The events are as follows Name – link channel mute. Trigger (Ch1), Mute Channel, On Action Mute (Ch41), On, While Active Name – Ch1 down kills CH41 Trigger (Ch1), Fader Below, -90 Action Mute (Ch41), On, Latch Name – Ch1 up un-mutes CH41 Trigger (Ch1), Fader Above, -89 Action Mute (Ch41), Off, Latch And I will just need to make this set per channel pair I want to behave this way. Any other suggestions on questions? |
What version of the software are you using? I was able to get it to function properly on my system. I'm using the latest build 2.9.1
Are you saying in version 2.9.1 that they added toggle to the field that [While Active] and [Latch] are in and this is the answer to making the mutes of 2 channels link together? The SC48 I am using is loaded with the latest version of the software. |
what i use as events is:
Trigger (or) Ch 41 channel below -50db Action mute Ch33, on, while active. if you program it like that, you will only need one event for on or off. but what you want with channel mutes you will need i think 2 events per pair. event 1: Trigger (or) Ch 41 mute channel on Action Mute Ch 33 on while active event 2: Trigger (or) Ch 33 mute channel on Action Mute Ch 41 on while active |
Thank you! |
SC48 pops when linking or un linking stereo channels | lorenaguey | VENUE Live Sound Systems | 7 | 07-16-2013 08:11 AM |
Touch beside the fader mutes the channel... | webstereo | ICON & C|24 | 2 | 08-24-2010 07:02 AM |
Is there a way to link track mutes to send mutes? | Ed Douglas | Tips & Tricks | 6 | 01-05-2010 06:39 PM |
Send Mutes to Follow Channel Mutes | Jeff E | Pro Tools TDM Systems (Mac) | 8 | 08-31-2009 08:05 AM |
problem: audio channel rec mutes in scrub | matt connolly | Pro Tools TDM Systems (Mac) | 0 | 02-14-2002 12:45 AM |
