Re: PT 12.6 Video Error
I don't remember if I tried disabling the video hardware - but why does it work once I've gone through all the hoops I discribed earlier?
I've tried a few different video files. ProRes, DNx, MP4. All with the same result. I really think it's a hardware problem, or at least something PT12.6 doesn't like but 12.4 is fine with. Avid support so far has told me to delete the prefs!! Thanks ... hadn't thought of that! Hopefully they'll have something more constructive to say. |
Also I've gone back to Mac OS 10.9.5.
The graphics redraw in ElCapitain was way too slow. I couldn't even read the Waves meter while mixing a big session. Same exact problems with PT 12.6!! |
I'm still having video errors as well in 12.6. Pretty much the same as 12.5.x. It mostly happens when editing fast in small increments. Like edit, playback, edit, playback, edit playback...error. PT says there is an error and I say no to restarting the video engine. I work a few minutes and restart the engine and it works for a while...then repeats. After about 3 or 4 of these errors it gets stuck and have to relaunch PT.
I'm on 10.10.5 using a separate 7200 rpm drive for video with Pro Res and DNxHD...never mp4's. I seem to remember that it does work fine when hardware is disabled so it may be the Blackmagic driver, 10.4.3 I think. Is there a stable version out there? Not sure there is. Are the Kono cards and drivers any better? |
Remove all video from your session, like everything. Even all the video tracks in your clip bin.
Close and relaunch the session. Then add the video. It should work, had the same issue after I updated. It only happens with old video sessions that were created before 12.6. Any new session is fine. *Also, remember to display your video track in blocks. This will stop video errors that come up when trying to display thumbnails, and also saves processing power that would be used to generate new thumbnails on every zoom in/out. Also, make sure you're using right click options to resize your video to 25% increments.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
~Will |
I've been clearing the bin and saving and it does the same thing once PT12.6 is quit and re-opened. I tried making a new session, just loading the video on a track and I get the same "video engine" error. I go through the same hoops to recover from that. I then saved the session, quit ProTools, reopened the session and I get the same thing. Tried 2 different videos from 2 different clients. One DNx, one mp4. (Don't let this degrade into an mp4 discussion, I never use it. It was only for testing purposes) I got it all working (with the steps outlined in the first post), disabled the video hardware. Saved, quit, reopened and I get the same results - doesn't work. It's got nothing to do with having the video displayed in blocks (which I always have) or thumbnails - it happens way before the session even opens. Vince |
The last version of Black magic would be 10.8.1. For me It solved a lot of problems but I am using SSD for system drive, audio and video.
Serge Hamel Mixer / Sound Designer http://www.netpostproduction.com http://immersivesoundvr.com/ |
I jump from HD 10 to HD 12,6. Video engine doesnt work AT ALL! First,i suspect that it might be Blackmagic drivers,and tryed every single one of them. No luck. Then i try to nail down where the problem is. I did every osx clean install from Mavericks to El Capitan,and always get same error "video engine have unrecoverable error",and of course when you try to launch,it cant. I also try all PT version as well. I have separate drives for audio,video and system. System is PCIe SSD,fastest possible,audio and video drives are 10.000 rpm Seagate,video files are all encoded to Pro Res LT or DNxHD,RAM is 32GB. I dont know where problem is,but i do know that is really really embarassing to have such expensive update which is totally unusablle! This issue starts with implementation of AVE,PT 11,and obviouslly is permanent. Please Avid,resolve this ASAP! |
'The Video Engine reported and error' message when trying to play any video | zerothrills | Pro Tools 12 | 10 | 02-28-2022 04:04 AM |
Video Engine Error? | bifbangpow | Pro Tools 12 | 1 | 09-29-2016 07:02 PM |
error when trying to bounce a video | oplatner | Windows | 6 | 11-15-2012 08:13 AM |
video error | radiosigurtwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 08-07-2008 12:00 PM |
Video Error | mroom | Pro Tools TDM Systems (Win) | 0 | 03-14-2007 10:19 AM |
