003 Rack Driver Issue
Hi, I was looking over the available driver downloads here : http://avid.force.com/pkb/articles/d...02-003-Drivers
I am on Mac OSX Mountain Lion 10.8.4 And I noticed 003 driver version 11.0.0 says it does not support pro tools 10. Does this mean I cannot co install PT10 with PT 11 and have my 003 working with both? |
Re: 003 Rack Driver Issue
I believe that's correct. I read that one user was changing is drivers back and forth when he changed PT versions. He wasn't pleased at the extra install.
Perhaps the two drivers can be installed at the same time and selected in boot. I don't think that's possible now.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
You can use PT10 and PT11 on the same machine and you can switch between PT10 and PT11 without rebooting. You'll just have to install both drivers. The 10.3.3 driver will appear as "DIGI 003" use this one in PT10s playback engine. The 11.0.0 driver will show up as "Avid 003". Choose this one in PT11. |
Well I went ahead and only installed the latest drivers (Version 11)
Everything works fine. I dont think installing 2 drivers is a good idea (even on mac) I see Avid 003 under playback for both PT10 and PT11. I also see Avid 003 in my control panel for mac. Also, I can share my mac system sounds, safari etc... with Pro Tools. Which is AWESOME! I think when avid says PT10 not supported they mean the control surface doesn't work. (maybe they should clarify it on the web page) Im just using a 003 Rack so the audio interface part works great! |
Now that is interesting!
It did not even occur to me to even try to co-install both drivers. I'm amazed that this driver co-install is not mentioned by Avid in the driver release notes or faq ... ... and a little disappointed that after I documented the woes involved in uninstalling one driver, rebooting, installing the other driver, and rebooting, which made co-install of PT10 and PT111 not the painless solution presented by Avid so far as 003 console owners are concerned, no one from Avid chipped in with any advice to install both drivers. I'll be trying this out later today and will report back. If two of us have it working, this might well be the solution. I'm still kicking my self for not thinking about installing both drivers, as they have different names ... duh
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
Yes, it's true ....
Keep the older V10 003 driver installed for use with PT10, and use the new V11 driver for use with PT11. Both drivers can remain installed at the same time. Just make sure you select the correct one in each version of PT, and you will have full control surface functionality active. Boy, do I feel stupid!
So I've installed the v11 driver and 003 won't show up as a playback device. What's worse is I tried finding a link for the v10 driver to do the ol' v11/v10 install switcheroo and the link for the v10 drivers seems to be broken. Is this not the correct link?
http://avid.force.com/pkb/articles/d...02-003-Drivers -Justin -EDIT - It appears I got caught trying to upgrade during the middle of Avid's weekend server maintenance and won't be able to get up and running again until the end of the day. Of course it had to be in the middle of a project too.
Justin Walker |
HELP! LE 7.4 and 002 Rack issue after new Rack firmware upgrade | monolithsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-13-2010 10:29 AM |
digi 001 driver issue | riverrush | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-02-2009 09:29 AM |
ASIO Driver Issue | yambike | Pro Tools TDM Systems (Win) | 3 | 09-23-2008 11:20 AM |
cpu 100% - maybe driver issue | DisplayName | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-14-2006 03:22 PM |
PT7 driver issue, any suggestions? | technician | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-08-2005 09:23 PM |
