Video bounce to same as source h264 Problem
This will only work if you have the very first frame of the video selected as part of the bounce. (Please see screenshot). Not very helpful, as more often then not bounces need to be done to show scenes or part of the file, not starting from the first frame. But I guess this is a promising first step.
MacbookPro M1MAX - 64GB Ram - 8TB SSD Mac Os Ventura 13.6.3 PT Ultimate 23.12.0.136
Sealove |
Re: Video bounce to same as source h264 Problem
Thanks for your response. I wish it was that simple.
h265 is not supported for bounce same as source. (Plz see the screenshot) I receive h264 (or DNX) from editorial. Just did a test for a 24 fps/48k PT Session using h264 video: 1) bouncing "same as source" from 1st frame for 1 minute took 5.5 seconds 2) bouncing for 1 minute from any place else in the session took 20.8 seconds 3) bouncing for 1 minute from h264 to h265 (same as source not allowed) took 22.4 seconds So I am hoping AVID will please provide same as source with h264 from any point in the session (not needing to include the first frame). Would be a HUGE time saver over the course of a show. Thanks!
Sealove |
Maybe I'm lost but how does Avid provide same as source from an arbitrary video file location here? h.264 is typically lossy encoded, you can't just cut the file at that point, and copy it to an output, you need to reencode/transcode it.
You can edit/export from any frame in h264. Lots of editors do it (the old QuickTime engine did it.) The first frame is re-written to include all the intercompression info. It’s not re-render because it’s just collecting the info for that frame and not re-compressing it (quality is the same)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Thanks for the clarification BScout.
I certainly do not understand all of the technical details, but bounce to video "same as source" was available with h264, DNX and I believe a few other formats until a year or two ago when it was broken, no doubt due to the EOL of Quicktime. It worked from whichever frame you designated as the start, up through the frame where the end of the bounce was designated. Useful for bouncing scenes to preview score and sound design for directors, execs, etc. Worked very well. Saved a TON of time! They have it partially working now as long as you start at the first frame, which is not practical for demonstrating scenes that occur later.
Sealove |
So AVID basically lied to us about the reintroduction of this, as the feature hasn't really been reintroduced if it's actually this half-assedly implemented?
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre 💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3 |
I've also just been using H265. But I'm not on 2023.12 yet.
~Will |
PT12 on Windows 7 Pro- no multiple bounce source tracks in Bounce To Disk window? | js_nyc | Pro Tools 12 | 6 | 04-21-2016 03:37 PM |
Why won't Bounce To Disk remember "Bounce Source" outputs? | midnightrambler | Pro Tools 12 | 3 | 07-16-2015 01:27 PM |
bounce source | glennloopez | Pro Tools TDM Systems (Win) | 0 | 08-30-2010 12:31 AM |
Video Sat LE not happy with H264 | Pirate Post | Post - Surround - Video | 1 | 06-01-2009 08:15 AM |
Bounce Source | montytx | Tips & Tricks | 13 | 10-06-2004 12:31 PM |
