Old 02-27-2012, 07:56 AM
therecordinghouse therecordinghouse is offline
Default PT9 Bus Names Changing
I am on PT9.0.6.
I can import session data just fine, bus names everything appears fine. I simply close and reopen the session and all my names revert to generic Bus 1-2, Bus 3-4, etc. Is there any solution to this? I am unable to find any documentation.
Lynn Graber
Studio and Mobile Recording, Fort Wayne, IN.
Old 02-27-2012, 08:38 AM
Talisker Talisker is offline
Default Re: PT9 Bus Names Changing
Once you have the busses named as you want it, go to the I/O setup (in the setup menu) and export your settings. Next time, your bus names go haywire, you can import those settings again (you might have to press " default" before and "delete unsused Paths" otherwise you will have, if I understand that right, your setup added to the existing paths) I hope, this is correct (I do it like that) and it helps.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Changing controller names Hugelittle MIDI 1 02-03-2010 04:37 PM
Track names changing by themselves Logic Pro Pro Tools M-Powered (Mac) 0 03-22-2007 12:16 PM
AudioSuite processing without changing file names waynekhin Tips & Tricks 1 08-10-2006 12:39 PM
File Names Changing.....Help!! Billmoss@Nola Pro Tools TDM Systems (Mac) 2 07-02-2002 10:30 AM
Changing Patch Names?? Mista Digga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2000 06:10 PM
