Cant get Pro Tools to find MC Control
Hello there.
Ive been having some problems with my MC Control in Pro Tools and wondered if anyone could help? I have the surface set up and it controls Logic under Eucon perfectly but no matter what I do I cant seem to get it working In Pro Tools while emulating HUI. I have added Pro Tools to the euphonix system preference pane but when I go into Pro Tools and assign the controller, though the ports show up, when I assign them the surface doesnt update and I cant control anything. I am running the latest version of EuControl with the latest firmware installed. I have tried: Downgrading Eucontrol and firmware to version 2.5.5 Re-Installing eucontrol Removing MIDI drivers that might be conflicting Running a permission repair Trashing EuControl and Pro Tools preferences then starting again. Pretty much all the FAQs on the euphonix site. I have also tried getting hold of euphonix support but the email for on their site doesn't work as it auto fills the email address section then says you haven't provided them with a valid email while not letting you change it. Has anybody else had any experiences like this? Any help would be greatly appreciated. Thanks very much. Tom |
Re: Cant get Pro Tools to find MC Control
Which version of Pro Tools are you running?
If it's 9.0, you should set it up using EuCon. Remove it from the Euphonix system preference panel then, in Pro Tools, go to Setups>Peripherals>Ethernet Controllers and enable EuCon. |
Hey there, thanks for the reply,
Im still using Pro Tools M-Powered 8.04 so HUI only :-( Tom |
Does anyone have anymore ideas?
Cheers |
Can't find Avid License control utility | soniad | Getting Started | 2 | 05-22-2013 03:05 PM |
Eq III for Pro Tools v9 where to find? | andre67 | Windows | 3 | 10-14-2011 07:36 PM |
Where can I find PT LE Laptop control instructions for a Macbook Pro? | JAZZ27 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2009 04:48 AM |
PT8 can't find Pro Control | satrackworks | ProControl, Control|24, Command|8 | 1 | 01-12-2009 03:30 PM |
Where i can find the serial # on the Control 24? | lvktv | ICON & C|24 | 1 | 02-12-2007 05:16 AM |
