Old 08-11-2016, 11:13 AM
legacygt777 legacygt777 is offline
Default Solo isn't working right
when i solo a track (ie bass), i still hear other instruments. has anyone had this issue? im running pt 10 with an avid mix.
thanks for your help.
Old 08-11-2016, 11:58 AM
hooksound hooksound is offline
Default Re: Solo isn't working right
Do you have any PRE sends on some of the other tracks?
Pro Tools 10.3.10, Cubase Artist 7.5.40, Allen & Heath Qu-16, Focusrite Scarlett 18i8 2G, Fujitsu Lifebook AH532, Intel Core i7-3612QM, 8 GB RAM, Windows 7 Professional SP1 64 bit
Old 08-11-2016, 03:47 PM
Southsidemusic's Avatar
Do you hear the same audio if you solo the track from inside PT without using the Artist Mix?
Also do you have the fader to "pre" or "post" as asked before me? Important!
Let us know what happens.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-11-2016, 08:57 PM
i'm not an expert. how do i check if I have any pre sends of the the other tracks?
yes. thanks.
Old 08-11-2016, 09:23 PM
jeffro's Avatar
jeffro jeffro is offline
Perhaps those 'other' tracks are in Solo Safe mode? From the Ref Guide:
Solo Safe Mode
Pro Tools lets you solo safe a track. This prevents the track from being muted even if you solo other tracks. This feature is useful for tracks such as Auxiliary Inputs that are being used as a submix of audio tracks, or effects returns, allowing the audio or effects track to remain in a mix even when other tracks are soloed. It is also useful to solo safe MIDI tracks so that their playback is not affected when you solo audio tracks.
To solo safe a track:
  • Command-click (Mac) or Control-click (Windows) the Solo button on the track. This prevents the track from being muted even if you solo other tracks. The Solo button changes to a transparent color in Solo Safe mode.
To return a solo safe track to normal:
  • Command-click (Mac) or Control-click (Windows) the Solo button on the track again
If you still can't get it sorted out, please post (or link to) a screenshot of your Mix window.
• linkedin •
Old 04-03-2018, 07:49 PM
JBSpring JBSpring is offline
The advice to click CMND + Solo on greyed out solo buttons fixed it for me.
Thanks for the help
much appreciated
EQ 3 7-band solo feature not working bluesguy76 Pro Tools 12 4 12-17-2018 02:44 AM
Solo Clear not working on S3 jmkeane Avid S1, S3, Dock and Control App 3 10-09-2015 07:34 AM
Fast track solo out of the box not working yoplin FireWire & USB Audio Interfaces (Mac) 0 10-10-2014 04:18 PM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
Solo function not working anymore original 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-12-2008 05:42 PM
