Old 11-06-2010, 08:37 AM
Venture Studios Venture Studios is offline
Default Help. Profire 2626 H/W buffer size no lower then 128?
Why can't I set the H/W Buffer Size any lower then 128 with the Profire 2626? Am I doing something wrong. I figure it should go down to at least 64 like it did with M Powered. Any help would be appreciated. Thanks.
Old 11-06-2010, 10:27 AM
Trevoire520 Trevoire520 is offline
Default Re: Help. Profire 2626 H/W buffer size no lower then 128?
??? I've never been able to put my Profire below 128 samples using Pro Tools?
Old 11-06-2010, 10:29 AM
necjamc necjamc is offline
Is this new to ver 9? on 8.0.4 I can go to 64. On Win 7 64bit. Perhaps it's the driver used, or are there settings for the driver in PT 9?
Old 11-07-2010, 04:00 PM
Anyone have any ideas or answers?
Old 11-12-2010, 07:50 AM
kaiserpathos kaiserpathos is offline
I got down to 64 on my ProjectMix IO by setting up an Aggregate I/O device instead of interface-only. Prior to PT9 & Aggregate feature, I could only go down to 128 on my Mac in PT8
Old 11-12-2010, 08:33 AM
Cool thanks the aggregate device thing worked.
Old 11-12-2010, 12:11 PM
tribedescribe tribedescribe is offline
Weird, I never could get my 2626 to go down to 64 samples on any version of PT8(currently 8.0.4 mac). I have not upgraded yet to 9, how did you get your 2626 to go below 128 while you were in PT8?
Old 11-12-2010, 12:22 PM
Mike@sunrisemedia Mike@sunrisemedia is offline
I use the Profire 610 with W7x64 and if I run it at 88.2 or higher I can get down to 32 for my buffer.
Old 12-21-2010, 11:01 AM
TheLastHobson TheLastHobson is offline
I would love to know how this worked... when I switch to aggregate device, the Profire 2626 does not show up, just my stereo mac i/o... I've read elsewhere that avid doesn't support m-audio interfaces as aggregate devices, but I don't know that for sure...
I'd just really love to get the latency lower than 128. it's just not great for pro tracking, or using software instruments...
Old 12-21-2010, 11:25 AM
Dism Dism is offline
You have to place the ProFire into the aggregate... it doesn't just "show up."
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
[IMG] code is Off
Can't lower the buffer size for HD Native & Omni with 3rd party DAWs? akhafaji Pro Tools HDX & HD Native Systems (Win) 3 05-27-2014 05:24 AM
Issues with H/W buffer size, using Profire 2626 and PT10 HELP! DavidNichols Pro Tools 10 3 01-02-2012 11:50 AM
Profire 2626 buffer size - any less than 256? risemymuffins Pro Tools M-Powered (Win) 2 10-05-2010 08:58 PM
Profire 2626 DSP Mixer buffer is locked on 64 Bits ubrnostrum Pro Tools M-Powered (Win) 26 05-12-2010 12:14 PM
Problem Solved--Profire 2626 DSP Mixer buffer is locked on 64 Bits ubrnostrum Pro Tools M-Powered (Win) 1 04-20-2010 12:36 PM
