MY i7 build parts list- any bad choices?
Hello everyone, I'm hopefully gonna do a custom i7 build for music production next week. I know there's already a thread for this, but it's huge and i'm afraid i won't notice major issues people mentioned.
If you could just look over this quick list of parts i plan to buy, and tell me if anyhing looks bad. Thanks. This is for Pro Tools 9, using alot of VI's Intel Core i7- 3930k AS Rock LGA2011 Intel X79 DDR3 CrossFirex SLI SATA3 USB3.0 A GbE ATX Motherboard X79 EXTREME6 ram- HyperX 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory HyperX Plug n Play Model KHX16C9P1K2/16 ( i have 2 pairs of these, so 32 gb , :) :) ) cpu fan- Noctua NH-U14S Case- Rosewill THOR V2 Gaming ATX Full Tower Computer Case Samsung Electronics 840 EVO-Series 500GB SSDx4 (one for OS, two for samples using RAID 0, one for Pro Tools sessions) graphics card- Gigabyte GTX 750 Ti GDDR5-2GB 2xDVI/2xHDMI OC Black Edition Graphics Card GV-N75TWF2BK-2GI getting power supply from older pc, 1000 watts (Only comes out to around $2k by the way, in case your anyones thinking of a build) Last edited by Natanel Arnson; 09-30-2014 at 08:51 PM. |
Re: MY i7 build parts list- any bad choices?
first off this looks like a great build, but i have a question for you......
do you plan on installing Pro Tools on a seperate SSD drive? if so, this will usually lead to problems with Pro Tools. OS and programs should be installed on the default c:// drive. samples, VI SOUND LIBRARIES can rest on a seperate drive. plugins and Virtual INSTUMENTS must be installed in the default c:// drive.
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
[QUOTE=
do you plan on installing Pro Tools on a seperate SSD drive? /QUOTE] I saw that too. Hopefully he means the drive will be used for the Pro Tools session files (Audio Drive) Also, don't forget to get a power supply with adequate wattage, and some good RAM. You didn't list these 2 items, so maybe you already have them from another build.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Yeah, i meant for the pro tools sessions to be on separate drive. Forgot to post ram, will update it. Thanks
Now that you mention it, does it help to have the pro tools sessions saved on a separate drive? |
Yes, ProTools sessions DEFINITELY need to be saved on a separate drive, at least separate from the SYSTEM (C) drive.
I'm trying to understand why you want RAID for your samples drive The rest looks like a serious beast
haha thanks. yeah wanted to do it right the first time. CANT WAIT to get out of my current pc limits.
Well, i want RAID for when I have lots of VI's streaming at once. I figured i might run up against an SSD's limit without RAID, which will go almost twice as fast as one reg SSD. |
You're not going to have that problem without Raid.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
http://www.asus.com/Motherboards/ThunderboltEX_IIDUAL/
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
But SSD's have a transfer rate of about 500 mb i think, so once I'm streaming more than that at once, won't i have issues without RAID?
Removing Playback Engines from list of choices | bcwiz | Windows | 0 | 10-08-2012 08:19 AM |
Removing Playback Engines from list of choices | GordonFreeman | macOS | 1 | 10-08-2012 06:03 AM |
Going to build an i7! Veterans can check you out this list of parts | spiritfallrecording | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-21-2010 08:38 AM |
I want to build an M-Audio PC, are these parts good choices? | beyoutofull1 | Pro Tools M-Powered (Win) | 6 | 07-29-2007 10:17 PM |
Cheapest place to buy (build) PC (parts) | billbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-19-2002 06:46 PM |
