Two embarrasingly simple questions from a new user!
Hi guys,
I have a twenty year history with Logic Pro, and am using Pro Tools 11 for a couple of projects at the moment. I'm using PT 11 native on a Mac. There are two operations that I haven't been able to figure out... which is embarrassing given the fact that they are both everyday processes! I have had a decent read through the PT manual and haven't been able to make sense. The two processes I'm struggling with are: 1. Cutting/splitting clips. I have been able to work out how to move, shorten (at either end) and copy clips, but haven't yet been able to work out how to split a clip somewhere in the middle. This is done with the scissors tool on other DAWs, but I haven't found anything like this in PT. 2. Continue playing from where playback stopped. No matter what record playback mode I use, it seems that when I stop playback, and then start it again, it goes back to the beginning of the track, or of the loop markers. Often I want to go through a whole track and make little edits, so I like to play a few seconds, then stop, then continue playing from where I was up to. I'm sure this is ridiculously simple in PT, but I haven't been able to figure it out as yet! Thanks in advance if you're able to help! Cheers, Mike
Mike Pooley (Sydney, Australia) iMac i7 3.5GHz + RME UFX + Event Opal + Nord Stage 2 + Korg Kronos 73 + Kurzweil PC3-61 + Dave Smith Prophet 08 + Roland Juno 106 + Roland V-Drums TD12 + Yamaha U1 piano www.thepeopledownstairs.com |
Re: Two embarrasingly simple questions from a new user!
1: cmd+e or edit> separate clip > at selection
2: if you have command focus on (the yellow az button top right of edit window) you can press the n key. Or press button under the pencil tool |
Also Fab fom puremix.com has a free video on their site and youtube about pro tools key command shortcuts which goes over how pro tools does this kind of stuff and much more. Its great, has a ton of info and it's short.
Cheers, Mike
It is weird using a different environment to one I have become so familiar with over years - but at the moment I really quite like what I am seeing in Pro Tools... and compared to a previous experience (with PT8 from memory), it has made huge steps forward in efficiency and running large numbers of low-latency instruments and plug-ins, too.
Those are actually not stupid questions. When I was using PT8, both those things weren't very apparently and it was frustrating to have to dig so deep to do the simple things. There are a few other "everyday" actions that aren't so apparent through the UI, too. I was kind of hoping they'd fix those things in PT11 but it sounds like they did not. Weird.
Good tips so far....also, you can drop your cursor in a region, then right click and "separate"
(Right click has a lot of handy options) And using the Smart Tool to select, with "Separation" for the hand tool is a very fast way to make edits and move portions of regions around. Try modifying with option to copy, control to lock to time, both for copy and lock. kasper |
The command you're looking for is called 'Insertion Follows Playback' It's the last icon on the lower set to the left of the counter, underneath the pencil tool. |
even easier, when in keyboard focus mode, just hit "B"
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
2 simple questions about PT 6.9 HD-TDM | MixerGuy | Pro Tools TDM Systems (Mac) | 5 | 07-05-2008 05:43 PM |
help strike user with simple questions, please | unitysunrise | Virtual Instruments | 1 | 07-15-2007 08:25 PM |
Very simple question from non-techie Mbox2 user | SessionSinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-05-2007 01:49 AM |
New Pro Tools User - Simple Questions | jimst57 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-03-2007 08:40 AM |
simple XP questions. | K.B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-27-2003 02:04 PM |
