Moving loop points
Let's say I'm composing. I want to work on my intro, then my verse, then my chorus. I set up loop points to compose my intro. Now I want to move on to my verse.
Is there any way to just grab the loop markers & move it as an object? IF you've ever done this in Logic, you know what I'm talking about. You highlight the bar in the ruler at the top, then you can grab it & move it..... like if you want to loop 4 bars at a time, or 8 bars, etc...
MacMini OS x 10.14.6 Core i5 2.5 GHz 16GB Eleven Rack |
Re: Moving loop points
You can try different methods :
create an empty midi track, make a selection comprising the "intro", consolidate that in the midi track, rename it to "intro". Same for verse and chorus. Switching between those selections is easy, just click the relevant midi clip. And maybe followed by Alt+F. Can also be done with an empy audio track. Or, make a selection, Enter numeric pad (make memory location), choose selection , name it accordingly. Shows up in the memory location window and is immediately selectable from there.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
If you switch on dynamic transport in options you can drag the selection around, similar to Logic...
How it behaves depends on how you've set link timeline and edit selection... Hope this helps Dan |
Thanks for the quick replies guys. joachim, that sounds easy enough.. like I should have already thought of that.
DDDaniel... I've got research to do. Thanks again.
It works just like it did in Logic, thank you.
moving automation points | pinnacle | macOS | 3 | 08-05-2013 01:36 AM |
Keeping Loop Points Set | xiaoxindiar | Pro Tools 10 | 5 | 03-20-2013 08:22 PM |
Rec In/Out points independent from play/loop points like DP has? | spiritG | Pro Tools TDM Systems (Mac) | 0 | 10-01-2009 04:40 PM |
creating loop points for the NN-XT??????? | speaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-20-2006 11:05 PM |
help with setting loop points | Equality 7-2521 | Tips & Tricks | 2 | 07-17-2005 11:40 PM |
