hardware insert with pro tools 9 motu 24 i/o
can someone please explain specifically how to use a hardware insert with pro tools 9?
when i play a click out through an analog output and into an analog input it does not line up. The delay seems to be 57 samples or on the min/sec clock 00:00:501. I have ADC enabled. The pcie 424 for the motu says the i/o latency is 8.33 milliseconds. the hardware buffer is set at 256. What number do i enter into the hardware insert delay tab? I keep reading to enable delay compensation on the input tab but i can't find this option. All i want to do is run tracks through an outboard compressor and have them be in phase with each other. I want to use parallel compression. |
Re: hardware insert with pro tools 9 motu 24 i/o
Turn on ADC: Options-> Delay Compensation.
Select a Delay Compensation Engine setting: Setup->Playback Engine and use the Delay Compensation Engine pulldown. Select Short or Long. See page 66 of the PT9 manual. Also see page 956. Enter you latency figures in the H/W Insert Delay tab of the I/O setup. See page 962 of the PT9 manual. These values are in milliseconds. If your box says the latency is 8.33 then enter 8.33 for the Insert Delays for each in/out pair you intend to use on the motu box. I'd probably then do a test as outlined in the manual to make sure things lined up. Put a H/W insert on a track and enjoy your outboard gear. See page 997 of the manual. |
Hardware Insert Latency issue in Pro Tools 10!!! HELP !!! | Hovak | macOS | 14 | 10-28-2012 10:42 AM |
pro tools 9 insert hardware??? | katch22 | Pro Tools 9 | 10 | 12-25-2011 11:53 AM |
Pro Tools 9 Hardware Insert Delay Compensation with Lynx AES16e and Aurora 16 | SolutionRoom | macOS | 0 | 04-08-2011 10:54 AM |
Pro Tools 7.4 Hardware Insert Question | Jaylaca | Pro Tools TDM Systems (Mac) | 2 | 02-12-2010 07:38 PM |
will Pro Tools LE software work with MOTU hardware? | Tweekhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-14-2001 09:06 AM |
