Pro Tools 7.4 Hardware Insert Question
Running PT 7.4 HD on Mac OS10.4
Using Digi 192 interface Session 24bit 96K I have a TC Electronic Reverb4000 on the AES/EBU bus. I can use it as a lovely send/return reverb. But I tried to record some gated verbs onto Audio tracks via Hardware Insert technique. Mainly because HW's are delay compensated. When using AES (aka [DigiEncl] in Hardware Setup) as an Hardware insert, Can I record the audio with the insert effects applied? How I tried it: (Audio Track) Track 1 Snare - assign output to Bus 1-2 (Audio Track) Track 2 Desired Gated Snare Audio Track - assign input Bus 1-2 Put outboard FX unit on Hardware Insert on Track 2 (in my case AES/EBU digital) Currently only the raw audio is re-recorded. If I take the hardware insert FX off (in this case a gated reverb), the recorded audio is just the raw audio from Track 1 re-recorded. What I currently do: Is send my snare Track 1 to the AES hardware ouput. Record the AES input to an audio track. Then manually nudge the new track by my latency (100 samples) to the left. Just wanted to stop having to do this. Thanks, Jason |
Re: Pro Tools 7.4 Hardware Insert Question
Move the hardware insert from track 2 to track 1.
No ,, that's not how it works. The inserts behave exactly like plugins. Top Jimmy has the answer ...
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2 Last edited by koo_koo_bonkers; 02-12-2010 at 07:41 PM. Reason: Top Jimmy said it all already |
OMNI ADC and Hardware insert question | K Roche | Pro Tools HDX & HD Native Systems (Mac) | 4 | 03-06-2011 05:21 AM |
Hardware insert delay question | musicmixer04 | Pro Tools TDM Systems (Mac) | 1 | 01-31-2009 07:33 AM |
Hardware Insert question | mcbv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-02-2007 08:08 AM |
Hardware Insert Question | Eless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-05-2006 07:32 AM |
Hardware insert question | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-14-2006 05:12 AM |
