Old 05-01-2002, 09:05 AM
WorldOfWiz WorldOfWiz is offline
Default no sound in plug in previews
I get sound when I play it. but when I use a plug and preview it. I hear nothing. I know I must have did something to disable it but I have no idea what I did.
Wiz
The underground is as fickle and shallow as the mainstream.
Old 05-01-2002, 11:35 AM
curve666 curve666 is offline
Default Re: no sound in plug in previews
if it's an AudioSuite plug, highlight the "use in playlist" button on the plug dialog box and try again.
Dan
dna
He Who Fears The Numbers 6, X & G5
G4 dual533, Digi001 + v5.2.1
Old 05-01-2002, 02:52 PM
ok it already was highlighted.
Wiz
Old 05-01-2002, 03:44 PM
tantejo tantejo is offline
hello, as a preset you can hear the preview only on the monitoring channels (channels 1/2)
you must set the preview channel to the channel in which you have set the plugin.
you can set these setting somewhere in the preference settings i believe.
i'm at home now, so i can't check it out, it is just from my memory.
it can be done.
greetings, tantejo.
(sorry for the bad explanation)
Old 05-01-2002, 05:34 PM
run that by me again..
Wiz
Old 05-01-2002, 11:34 PM
ok, sorry, i'll try again.
if you have a channel assigned to output 8 and you want to listen
to the preview of a audiosuite plugin you have to assign the output of
the preview bus to output channel 8. by default the output of the preview bus
is assigned to channels 1 and 2.
so you can listen to the preview by listening to channel 1/2 or you can change the
outbus assignment of the preview bus. (every time when previewing !)
and here i can't remember exactly how you can set the output of the previewbus,
but i think you can set it somewhere in the settings -> preference dialog or in
the i/o setup. (i believe it's the last option). i have a protools free at home, but i
couldn't find this option in it, although i'm 100 procent sure it is in the mac version 5.1,
because i use it sometimes. (with dinr for example)
i won't be in my studio untill saturday so i hope that you can figure it out for
yourself by now, or that digisupport helps.
greetings, tantejo.
Old 05-02-2002, 02:19 AM
tantejo:
Thanks you have been a big help. I have sound now.
Wiz
RANT: Previews at movies too loud! John Link General Discussion 14 05-13-2023 04:53 PM
Previews / Bought wrong version barbecue Avid Scorch (iOS) Forum 5 10-22-2011 01:34 PM
No sound previews from Xpand!2 fastdog Pro Tools M-Powered (Win) 5 09-15-2010 02:22 PM
EQ III previews only one channel, doesn't process changes ASchalk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-18-2010 12:37 PM
Anyone make any guesses at what 6.2 will contain??? Any sneak previews Digi?? :) stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-03-2003 02:46 PM
