EQ III previews only one channel, doesn't process changes
I recently ran through the full update process of bringing PT LE 8.0.0 up to 8.0.4. One thing I noticed in the upgrade to 8.0.1 was that I lost proper function in EQ III / 7 band eq. It would not preview both channels in stereo, not would it apply the desired eq changes to the track itself.
I continues the upgrade to the current version of 8.0.4 and the same behavior persists. Any ideas? I've imported older files that I've worked with properly before, and the same symptoms continue. Leads me to believe that it's a setting or configuration issue, and not a source file problem. Have there been updates to EQ III? Thanks for your help, |AAron |
Re: EQ III previews only one channel, doesn't process changes
I guess you're using the plugin in Audiosuite?
Make sure the "Use in playlist" button is activated. You should clear preferences when updating.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
RANT: Previews at movies too loud! | John Link | General Discussion | 14 | 05-13-2023 04:53 PM |
Previews / Bought wrong version | barbecue | Avid Scorch (iOS) Forum | 5 | 10-22-2011 01:34 PM |
No sound previews from Xpand!2 | fastdog | Pro Tools M-Powered (Win) | 5 | 09-15-2010 02:22 PM |
Anyone make any guesses at what 6.2 will contain??? Any sneak previews Digi?? :) | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-03-2003 02:46 PM |
no sound in plug in previews | WorldOfWiz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-02-2002 02:19 AM |
