Second pair of monitors
For those that has several pairs of monitors connected to the XMON - do you use the TB/LB/UTIL DSub connector? And, does such a snake exist, as shown in "D-Command_Monitor_44748.pdf"? It has 5 XLRF and 3 XLRM.
Thanks.
Re: Second pair of monitors
BTW, I'm thinking of getting a pair of Avantone active Mixcubes. Anyone tried them?
We do use the TB/LB/UTIL DSub connector for AFL, the mini speakers, TB out, and a listen mic. We made our own connector with only the cables we needed. I am sure you could order such a cable from Redco for example, but I can't imagine such a configuration off the shelf so to speak.
And no, haven't tried the active mix cubes. We use something smaller and lower quality for tv speaker reference. |
Sweet! Thanks, Craig.
Guys, I need some help here.
I ended up buying a DSub-XLRF snake, and I've connected it to the TB/LB/UTIL. I've made two cables with XLRM in both ends, and connected them to outputs 6 and 7 of the aforementioned snake. When I press Mini on the console, there is signal to both speakers, but it's weak, and shifted to the right. Both speakers are currently set to +6db gain. I must have done something wrong. Thoughts?
I flipped the cables at the speakers, and the signal shifted to the left. Hmmm...
Never mind...soldering is not for me.
FS Tannoy PBM 6.5 Monitors PAIR | degs7 | Buy & Sell | 0 | 11-10-2013 04:34 PM |
audio through second pair of monitors? | korkman | Windows | 6 | 03-28-2012 12:38 AM |
Equator D5 Monitors $299/pair ??? | EGS | General Discussion | 3 | 02-21-2012 12:57 PM |
THE BEST PAIR OF MONITORS FOR UNDER 500.00 | 7 MO-BEATZ | Tips & Tricks | 42 | 05-10-2005 10:23 AM |
A/B-ing 2 pair of powered monitors from the 001? | Kickin.da.speaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-05-2001 08:31 AM |
