Old 02-13-2003, 11:57 PM
benderbro benderbro is offline
Default "Deleting Unused Fades"
I just started seeing this lately when closing a session, the progress bar takes a few seconds and then the session is closed. This is on HD2 with version 5.3.1 on a 1 GHZ dual processor.
Anyone care to chime in on what this is all about?
"this guitar won't play that"
Old 02-14-2003, 04:05 AM
protooleriate protooleriate is offline
Default Re: "Deleting Unused Fades"
I think its when you try a load of fades out to see which works best, PT writes them all to disk, and then when you save it deletes the ones you didn't use.
Old 02-14-2003, 08:41 AM
CLee CLee is offline
also, if you have more than 1 session in a folder sharing the Audio Files and Fade folders, such a 2 versions of the same spot or 2 reels of a film, when you close the session PT deletes any fades not used in that session.
Craig Lee@Cerny American
Old 02-14-2003, 10:59 AM
MDH25 MDH25 is offline
It does this when you open a session, and it renders a bunch of new fades (if you tell it to skip all fades for example) then you close the session without saving...
Moving Plug-ins to Unused - Does this "help" PT operate faster/better? lowlights Pro Tools 10 6 12-28-2011 12:55 PM
fades link is "greyed out" can't click to access them Daviat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-19-2011 02:34 PM
Deleting Projects from "Recently Opened" Sound Student 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-23-2010 03:28 PM
Where is "delete unused regions" now (LE8)? Dr Scary 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2010 07:25 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
