CPU Overload
Hi everyone... I need your help
Once again... I have extreme basic knowledge of pro-tools and all things technical, so bow down to your advice. I have NO plug-ins. My imac has more than 800gb of free storage. But I get this following message when I try to record a voice-over session... "A CPU overload error occurred. If this happens often, try increasing the "H/W Buffer Size" in the Playback Engine Dialog, or removing some plug-ins. (-6106). Anyone have any idea what this means, or how I can fix it? When it pops up, my recording is stopped. This can happen after 1 or 2 seconds, or as soon as I hit record, or a minute or so into the session... or not at all. Any broken down, plain English advice would be greatly appreciated. Thanks in advance! |
Re: CPU Overload
Go to:
Setup/Playback Engine •Change the H/W buffer size to a higher value •Change Host Processors to a higher value (ex: if your imac is a Core2Duo select both cores or if it is an i7 cpu choose a higher number but leave at least 1 or 2 processors free for other background stuff) •With the above steps completed, change CPU Limit to 80% (if you have a CPU with more than 2 cores select 99%, but remember to leave at least 1 or 2 processors free, like I mentioned in the second point, if that is possible
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
Re: CPU Overload
Are you trying to record to your ONLY hard drive? You NEED a separate(approved) hard drive for recording(you create and save your sessions on the recording drive).
Re: CPU Overload
Thanks everyone. We've done all that you've said and we'll see how it goes in the session tomorrow
Thanks very much! |
Re: CPU Overload
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
cpu overload | maxidud999 | macOS | 3 | 03-14-2013 06:48 PM |
CPU overload | jeradbay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-31-2009 06:47 AM |
CPU overload | aldoriba | Pro Tools M-Powered (Mac) | 1 | 12-09-2008 05:25 AM |
CPU overload | marcvise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-06-2008 12:56 PM |
CPU overload | Raggi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2005 02:49 PM |
