#21
Re: HDX 192 "-10" analog inputs - ok for use 'alternate +4 inputs ?
Ill put you up in my waterfront guesthouse next to the studio when you hit Arlanda
#22
The -10 inputs are balanced so I would assume that you'd be okay. Just calibrate them to see the output of the machine that you will be using.
Steve
Steve Shepherd Extreme Mixing |
#23
Oh man are we going around in circles. The OP was trying to get to wether he could adjust those inputs to a suitable level. That is not obvious anywhere in any doc. He asked it in a round about way by asking how the circuit is implemented (it's implemented how anybody sensibly would and is obvious from looking at the board, that the -10 dbV and +4 dBu input front ends buffers are different) and so that *still* leaves the question of whether there is enough adjustment in the -10 dBV input trims to accept input from a nominal +4 dBu device. Thats ~12dB difference. I have never measured the input calibration trim dynamic range on a 192 IO, but if I had one sitting in front of me it's a minute or so with a screwdriver, jumper cable, and signal gen plug in to answer that question. I'd be surprised a bit if the adjustment is ~12dB or larger given you want temperature and mechanical stability in the 10 turn pot and small fraction of a dB resolution. But hey, again I think we are back to if ya got one on in the rack just go measure it/try it. (I really wish I had one with me, I'd just measure this and be done :-O) Last edited by Darryl Ramm; 12-09-2018 at 11:34 AM. |
Monitoring "stereo" inputs through Mbox Mini | Larry O | FireWire & USB Audio Interfaces (Win) | 8 | 04-21-2015 10:31 AM |
Inputs automatically reassigning after selecting "no input" | BrianJArmstrong | Pro Tools 10 | 4 | 05-30-2012 09:12 AM |
Losing "track" of VI virtual inputs | PTcomposer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-15-2010 01:38 PM |
Superior Drummer 2.1 -- "S1/2" inputs are not an option on PT tracks? | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2009 01:52 AM |
Anybody used "NitroAV 2-Port FireWire800" express card slot for firewire inputs? | TonyFla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-03-2008 07:20 AM |
