Sends View Help! (w/ and w/o fader in channel)
There is a command (or modify click) that turns a send button into a little fader in the actual channel strip itself in mix view.
I did that for Send A and forgot the command so I can't get it back to see the other four send buttons. D'oh! I'm not even a total noobie, but I feel like one. I've tried everything to lose the fader and get it back to showing the usual five send buttons A-E but can't figure it out. Anyone know how to switch between those views?
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave. |
Re: Sends View Help! (w/ and w/o fader in channel)
right click on the send itself, then you´ll get að dropdown menu where you can select which send you want to have displayed. There is also an option called "sends view" i think. That´s the one you´ll want.
"Ok I promise, this is the last plugin I´ll buy!" www.syrland.is www.sturluson-music.com |
I'm not a MAC user, but use the equivalent of ctrl click on the sends to "turn" them into little faders. - or go into preferences and select "sends default to faders", or something like that - also read the manual many times, over again.
Baris. |
I'm using Pro Tools 8 if that makes a difference.
I don't know the key command, but go to views>sends a-e
Change it from "send x" to "assignments"
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Worked! Thanks so much...
C/24 sends view ? | jackp | ICON & C|24 | 1 | 10-21-2012 09:02 PM |
View multiple sends in fader view. | yamahadrums | Pro Tools 9 | 6 | 03-07-2012 06:53 AM |
Multi-channel plugin default 'channel view'? | Floydio | Tips & Tricks | 1 | 11-26-2010 10:47 AM |
Sends F thru J fader view follows each other problem? | jackp | Pro Tools TDM Systems (Win) | 3 | 06-21-2010 05:17 AM |
6.1.1 sends view | mixerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-05-2004 06:54 AM |
