Old 06-23-2013, 12:08 PM
rus5 rus5 is offline
Default Eleven Rack Doesn't Connect to PT11HD
Is anybody else having problems getting their Eleven Rack to connect to PT11HD? Sometimes it shows up grey'ed out in the "Window" drop down, and sometimes it doesn't show up there at all? No problem with PT10HD. Weird...
Old 06-23-2013, 12:24 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Eleven Rack Doesn't Connect to PT11HD
Are you running 10.3.5 and that works ok but 11 isn't seeing it sometimes?
Any pattern to it? If you boot fresh and load 11 first does it see it?
What about booting holding down the N key then assigning it as the audio device!
Is it showing in the AMS audio midi setup? Next time it's greyed out in 11 check the the AMS and see if it's showing.
Have you installed the latest driver!!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-23-2013, 12:28 PM
Benoni's Avatar
Benoni Benoni is offline
Are you talking about not being able to use it as an interface OR the on-screen editor not coming up?
Are you talking about the pop up that says "Eleven Rack #1" then "Eleven Rack #2 Could Not Connect"
That is because the on-screen editor is not available at this time in PT11.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 06-23-2013, 01:28 PM
Hi to Benoni and Crizdee,
Thanks for the responses. It always shows up in the PT10 "Windows" drop down (which I can select and then use to adjust ER). It never shows up in PT11, no matter whether I've started PT10 since the last reboot or not. Rebooting the computer or restarting PT11 doesn't change anything. Sometimes I get a dialog saying its having trouble connecting to ER, sometimes it says its obtaining setup information then throws a "Can't communicate with Eleven Rack" error, but most of the time it just boots and the Eleven Rack simply doesn't show up in the "Windows" drop down. It always doesn't connect to the Eleven Rack. It always works fine in PT10. It shows up in "MIDI Input Devices" (internal and external) and is checked. There is no pattern. Any help would be appreciated.
Thanks,
Russ
Old 06-23-2013, 01:36 PM
Benoni's Avatar
Thanks for the responses. It always shows up in the PT10 "Windows" drop down (which I can select and then use to adjust ER). It never shows up in PT11, no matter whether I've started PT10 since the last reboot or not. Rebooting the computer or restarting PT11 doesn't change anything. Sometimes I get a dialog saying its having trouble connecting to ER, sometimes it says its obtaining setup information then throws a "Can't communicate with Eleven Rack" error, but most of the time it just boots and the Eleven Rack simply doesn't show up in the "Windows" drop down. It always doesn't connect to the Eleven Rack. It always works fine in PT10. Any help would be appreciated.
Thanks,
Russ
But your Eleven Rack DOES work as an interface correct? Meaning, you can record with it in PT11, you just don't have the on-screen editor. Is that correct?
If so, that is because the on-screen editor IS NOT COMPATIBLE with Pro Tools 11 at this time. Meaning you will NOT be able to adjust parameters from the screen. It is normal for the "Eleven Rack" to not show up in "WINDOW" because it is not compatible at this time.
It works in PT10 because it is compatible in PT10.
http://avid.force.com/pkb/articles/c...m-Requirements
scroll down to "Plugin Compatibility"
Eleven Rack UI not available in Pro Tools 11
Workaround: use Pro Tools 10.3.5 or higher Pro Tools 10.x version
Open the READ ME provided with Pro Tools 11 and search "Eleven Rack"
Eleven Rack Guitar Window not available in Pro Tools 11 (PTSW-184398)
Pro Tools 11 does not provide the Guitar Window for Eleven Rack that is available in lower versions of Pro Tools.
So, its completely normal not to have the on-screen editor. I have an Eleven Rack as well, and show just what you are talking about in this video:
Pro Tools 11 - Install, Activate, Open, w/PT 10.3.6
http://www.youtube.com/watch?v=WADEKsvVjfU about 7:19 you will see the dialog box you are talking about.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-23-2013, 02:01 PM
Hi Benoni,
Thanks for the response. No, it does not work as an interface. It doesn't show up in the "Input" list (as it does in PT10) and when I open PT11 with a template that includes a guitar track and uses Eleven Rack as its input, "Eleven Rack" is greyed out in the "Input" field.
Thanks,
Russ
Old 06-23-2013, 02:04 PM
Benoni's Avatar
Hi Benoni,
Thanks,
Russ
Did you default the IO? Templates have always had the wrong IO settings for me.
http://www.youtube.com/watch?v=-Rjk5qVFEE8
Have you installed the Drivers?
http://www.youtube.com/watch?v=jivq4bxYJwo
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-23-2013, 02:14 PM
zedhed's Avatar
zedhed zedhed is offline
I think your referring to the GUI window here. As Benoni stated, this won't show up in PT11...yet...so don't worry about that for now.
Thanks,
Russ
In PT11 upon opening, I get the 'Loading 11R info' popup then I get a repetition saying loading info for 11R #2 (where I only have one), & get a prompt asking if I want to re-connect to 11R #2. I choose NO and the popup goes away.
At this stage the 11R is actually working properly, albeit without the GUI.
If you go to Pro Tools>Setup>Playback Engine, the 11R should be showing up in there either as the chosen engine or as a choice in the drop down menu if you are using more than one interface. If it is showing up there, providing your I/O setup is correct, you should be able to use it in PT11 notwithstanding the anomalies stated above.
Make sure your I/O is correct by; Pro Tools>Setup>I/O setup and click the default button on each of the Input/Output/Bus Tabs....click OK to close.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 06-23-2013, 02:18 PM
Thanks again for the response
I am running a Mac and the link is for Windows, but I installed the driver file that was included in the PT11 download. Recall that it works fine on PT10 (and has for years). And yes, the I/O input, output and bus are all set to default.
Thanks,
Russ
Old 06-23-2013, 02:24 PM
Thanks for the response. Yes, it does show up as an audio engine choice. However, when I select it and restart as required, the session will load as if everything is normal, but the Eleven rack still doesn't show up as an input option. There is no way to get the eleven rack signal into the session.
Thanks,
Russ
Eleven Rack won't Connect to Omni IO Regg-4 Eleven Rack 1 10-19-2013 10:08 PM
How to connect the Eleven Rack and a Pod HD together webstersp Eleven Rack 5 01-04-2012 04:02 AM
Connect iPhone to Eleven Rack Pluck Eleven Rack 7 10-13-2011 08:10 PM
Eleven Rack Won't Connect bloodbath666 Eleven Rack 1 03-24-2011 05:03 AM
Eleven Rack won't connect spandol Eleven Rack 2 02-02-2011 08:32 PM
