Old 07-27-2023, 06:33 PM
briaboy briaboy is offline
Default Problem moving plugins back into Avid Plugins Folder
Hi - I just moved all the plugins from a session to the Unused plugins folder to try to locate a crash problem. I found the plugin that was causing the problem, but now when I try to move some of the plugins back into the main plugins folder, I get a message saying "The operation can't be completed because "name of plugin" needs to be downloaded". The plugins are not in the Cloud or anything like that, so I have no idea what this means or how to fix it. Any ideas?
Thanks!
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
Old 07-27-2023, 07:46 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Problem moving plugins back into Avid Plugins Folder
Hi, Which plugins are producing the message - or is it all of them?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-27-2023, 08:00 PM
Thanks - Izotope RX8 Deesser, Sonarworks SoundID Reference, Avid Trim, and Avid Dynamics III. All the others (around 20 by UAD, FabFilter, Waves etc) all moved back no problem!
Old 07-28-2023, 07:45 AM
Problem solved - I needed to change Mac User permissions to "Read & Write"!
Thanks again.
copy AAX plugins to new rig’s Avid plugin folder? MixerGuy Pro Tools 2020 3 04-01-2021 06:59 PM
Please can we move Avid Stock plugins into the "un-used plugins" folder [solved] Electronic1982 Pro Tools 12 9 01-13-2017 12:51 PM
Moving RTAS plugins folder - ProTools 10 thghgv Windows 5 05-27-2013 07:46 PM
PTHD 10 DEMO - Plugins Folder Problem? Allan Speers Pro Tools 10 2 09-10-2012 12:25 AM
Strike Keeps moving to Unused Plugins Folder Keefriffhard Virtual Instruments 4 04-08-2009 04:50 PM
