Effects delay on tracks
Ok,
How do I compensate for delay when I have effects on the vocals tracks pre fader example if I use a big effect and it gives me a reading of 3231. (in green in the mix board of the vocal track) what do I so that I can sing along in real time. willl3
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram |
Re: Effects delay on tracks
Why are you using effects while tracking? What plugin are you using that is giving you so much latency?
I'm using something like a pitch shifter. Do you know of any good auto tuners (not antares)
thanks willl3
Either way, a "pitch shifter" or "auto-tune"-like plugin, is not something you want to be using while tracking. Plugins like that are meant to be used after you have recorded the parts; during mixing. If you need to do additional tracking over an effected track, you should print the effect to track. If you want a great "pitch correction" software, I can recommend Celemony Melodyne. It is by no means "automatic" and can not really be used like you are trying to use it, but as I mentioned, you shouldn't be anyway. It's not even recommended to run Antares Autotune in real time; you should always process the actual track.
How to you fix this problem....? I know I shouldn't do this but I need to know how to fix this problem Meaning is there someplace in protools to adjust the latency if one track is off due to plug in's
will3
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing | CNSound | macOS | 1 | 01-27-2012 11:10 AM |
choral delay and reverb effects | frcjt | macOS | 0 | 09-09-2011 10:54 AM |
Bounces with effects not delay compensated | Ash06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 02-19-2007 03:20 PM |
delay issue with external effects | vx2kfilmer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-30-2003 09:59 PM |
reverb/delay/effects etc.- recommendations?? | MrMike | Tips & Tricks | 5 | 06-24-2001 08:06 AM |
