Newbie Question - Monitor..
I have an issue/question..you can see in my signature what my system setup is...I do voice-over work and am a newbie...have everything connected correctly or so I think, yet when I listen back via my monitors, only one of them provides playback...thoughts, suggestions? Thank you kindly! Within the mac's preferences for sound output it says there is no audio control when i select the mbox 2, like there is when I select it for input (via the mic)
15" Macbook Pro Unibody (2010) model 8GB, 240GB SSD Mbox Mini 2 KRK RP8 Rokit G2 Powered 2-Way Monitors (2) CBI Ultimate Series XLR Male to 1/4in TRS Cables Shure SM7B Microphone XLRF Cable Shure SRH440 Closed Monitor Headphones Adobe Soundbooth CS5 (mac) |
Re: Newbie Question - Monitor..
power to the 2nd monitor? cable hanging loose? if you hear one, and you make a master fader in Pro Tools and see metering on both channels, it's unlikely to be a software problem.
What are your speakers and how exactly are they connected?
I have power plugged into both speakers, they are KRK Rokit G2s 8"...each speaker has its own power cable..and they both light up on the front so they are getting power..XLR cables into the back of each speaker then they go directly into the TRS ports on the mbox 2 mini...if I switch the ports, on the back of the mbox it appears as though only the right channel is working...thoughts??
actually, do I have to use pro tools with the mbox 2 mini?
Heya...!
How have you set your Mix Knob...?
Green Room Studios, France Mac Book Pro i7 15"4 Mac OSX 10.6.6 PT 9.0.2 DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate. PTLE 8.0.4 002R Unit and MBox Mini SSL XLogic Alpha Channel. SPL Goldmike valve Preamp. DBX Analog Compressors, Gate and Eq. Monster Cables Home made & Neutrik Patchbay. Brauner, Shure, Seinnheiser and T.Bone mikes. Tannoy 8D Active monitors. |
all the way to the right
Monitor Audio During Recording....help for newbie | visionstudios | Pro Tools 10 | 12 | 09-05-2012 07:18 PM |
Newbie post/dual monitor/plug-ins | Troy Tracks Studio | Pro Tools M-Powered (Win) | 3 | 04-30-2010 12:20 PM |
PA question for newbie | metaltim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-04-2006 02:12 PM |
newbie ? Can't monitor new input & recorded stuff | Lugh98 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-06-2005 05:56 PM |
Serious newbie question :D | Palli-Moon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-23-2005 10:06 PM |
