Working on both Mac & Windows
Hi guys, got a question about working on both platforms
I have 2 001s, 1 at home on a Windows PC, and another at the office on a G4 460Mhz (both work fine - thank goodness). I hope to bring projects back home to work on them (trim, add fx, EQ and basically get a rough mix going), and take the project back into the office for the final mix. The plan involves transfering the files via CDRW Am I in trouble here? Any tips & tricks about saving the projects onto disk for constant loading/ saving/ reloading between the 2 platforms? Cheers from Singapore Leslie [email protected]
Leslie |
Re: Working on both Mac & Windows
Guess nobody's doing this just yet
Oh well, time to experiment. I'll post up the results in the hope that it will benefit somebody [img]images/icons/smile.gif[/img]
Leslie |
I haven't done exactly what you want (I only have one 001 system), but it SHOULD work if you use the Joliet format. It keeps long filenames and can be read on both Mac and PC. I haven't tried it with PT files, tho'. The ISO format makes everything an eight dot three format.
I wouldn't bother with CDRW. It's cheaper for me to just toss the disc when I'm done rather than have to go through the process of erasing the CDRW before I can use it again. CDR's are only $.30 or less each any more.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Thanks for the reply. I'll try it and post the results. Working across platforms has thus far proven to be a real hassle!
Leslie |
I thought of another possibility:
Try Retrospect. There are both PC and Mac versions available for about $50 each. Retrospect will allow you to span CDRs if you run over the capacity of a single CDR. It might be worth an email to their sales dept to see if the PC format can read the Mac format. If it works, it would be a pretty good solution. Try www.dantz.com
I have this problem too. I use Direct CD to burn pc CDRW and apples own software to burn on the mac.
I find i can't save to the other platforms discs but I can read them. I therefor use a 2 disc system to exchange files. |
32 bit not working in Windows 7 | Hamilton1 | AAX Plug-ins | 5 | 12-04-2013 10:44 AM |
M-Box Pro 3 not working with Windows 7? | dedikke | Pro Tools HDX & HD Native Systems (Win) | 1 | 01-29-2013 03:33 AM |
M Box 2 not working at all windows 7 | lowlevelowls | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-16-2009 06:31 AM |
OT- is Windows working on a new OS? | TheLP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-28-2004 01:04 PM |
Working with Windows | tucum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-23-2001 05:43 PM |
