PT10 and PTHD9 iLok licenses, moving between 2 keys
I have 2 iLok keys, one contains PTHD9 and another contains PT10.
When moving PTHD9 license to another iLok, iLok.com says: Step 5 - Review your selection and transfer: You have selected 3 licenses/bundles for transfer to your iLok named "iLok 3". Note: The following licenses exist on the target iLok and may be replaced by licenses selected for transfer. Please review the list below to make sure that you wish to perform these license replacements: Product Company Action Pro Tools 9 Digidesign Will be queued since another license with greater weight is in the way. Press the "Next" button to transfer the selected licenses from the source to the destination iLok. Press "Cancel" to cancel the transfer operation. It is because PTHD9 bundles: * PTHD9 * PTHD8 * PT9 and PT10 bundles: * PT10 * PT9 so PT9 license is common in both. Can I continue Next without loosing one of PT9 license from either PTHD9 or PT10 ? Or, one of PT9 will be lost ? Answer: Yes, we can. Please refer: http://duc.avid.com/showpost.php?p=1871201&postcount=9 |
Re: PT10 and PTHD9 iLok licenses, moving between 2 keys
I would be more concerned you may overwrite the entire bundle!
The ilok site does caution never to move a license onto another ilok that already has that license. Considering there is a common PT9 license in the two bundles, you are correct in having some concern you may overwrite PT9, but I wonder if one bundle would just replace the other. I vote: "bad idea," but maybe someone who has actually tried can give you the real skinny. The ilok warnings sound too cryptic to me. In your case, you could lose both PT HD8 and PT HD9 going one direction, or PT 10 going the other. You could potentially lose all the complete production toolkit functionality of PT HD9 or be unable to use any HD systems. Not sure why you would want to do that. Adrenaline rush? Walkin' on broken glass? |
I just want to have one iLok key that contains both PT10 and PTHD9, but not tried yet because of iLok.com warning message. Actually, I have another similar issue on Waves bundles. |
Maybe there is a geek out there that can figure a way to partition your ilok so you can carry only one, but have the security of not losing your "doubles." I used to use a program called "Partition Magic" that could do fancy stuff on my PC hard drives...outside of of fdisk or diskpart.
Bundle licences cannot be 'splitted',and the ilok is not just a simple flash device imho
Has somebody tried such a "move licensense" operation on iLok keys ? |
Be careful, you might bungle the bundle!
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Waves Tech Support answered that I can continue Next, and actually it was OK.
I have Diamond Native bundle, and L3-16 Native bundle. Both bundles contains 4 L3(-LL) Multi/Ultra-maximizer licenses. I moved L3-16 bundle license to the iLok which had already had Diamond bundle, and I did not loose any license. However, "queued" is displayed at iLok.com for 4 sub-licenses of L3-16 bundle license. According to my experience on Waves bundles, I guess it should be OK to move PT10 (PT10 + PT9) license to the iLok which had already had PTHD9 (PTHD9 + PTHD8 + PT9) license, and PT9 sublicense of PT10 bundle would be "queued". |
I found that iLok does officially support this feature.
http://ilok.com/ilok-faq.html#LIC160 Quote:
From the sound of the FAQ response, it IS possible to split a license from a bundle. May or may not be in tune with the publisher's licensing policy, though.
FS: ilok licenses | nedd | Buy & Sell | 7 | 12-09-2014 05:54 PM |
Ilok Transfer Issue bundled license PTHD10, PTHD9 | petesteen | macOS | 16 | 11-11-2013 03:39 PM |
How to transfer iLok licenses from old to new iLok | mschaeffer | General Discussion | 3 | 08-16-2013 05:55 PM |
moving cursor using arrow keys | jordya | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-14-2010 05:08 PM |
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-07-2009 03:51 AM |
