2022.9 Zoom bug?
After updating to 2022.9, Using Zoom tool zooms in waaaay to close...to a solid fill view of the track...but only on the top track. Zoom functions as normal on the other tracks.
See attached images... Anybody else experiencing that? -John |
Re: 2022.9 Zoom bug?
Double click the zoom button resets zoom view.
Well known problem for a decade.
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap |
Nah man. That ain't it.
Only affects track one...other tracks zoom in as expected See pic... -John |
How are you zooming? I don't have enough info or it is not reproducing.
All the ways I can think to zoom in don't do that unless my mouse moves like a pixel after I use zoom tool to click and then I let go, making a very small selection fill the entire view. Otherwise, everything seems normal for me, and that above IS what I would expect.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
I appreciate the help. It's not what I thought...
What I thought was a ZOOM problem is actually an "imported audio file becomes loud white noise." Only happened to 2 imported WAV files...and I imported 15 or more WAVs. They did play back normally initially but after saving and re-opening session: white noise. No wonder the zoom in looks like that. If I zoom out, the waveform looks normal but when played is really 0dBfs white noise. Dang. Original file in its original location is corrupted as well. WTH? Did a search on "imported audio white noise" but didn't get any relevant hits (other than someone experiencing this after importing MP3s). -John |
I appreciate the help. Thank you. It's not what I thought...
What I thought was a ZOOM problem is actually an "imported audio file becomes loud white noise." Only happened to 3 imported WAV files (drag and drop)...and I imported 15 or more WAVs. They all played back normally initially but after saving and re-opening session: white noise for three of 'em. No wonder the zoom in looks like that. If I zoom out, the waveform looks normal but when played is really 0dBfs white noise. Dang. Original file in its original location is corrupted as well. WTH? Did a search on "imported audio white noise" but didn't get any relevant hits (other than someone experiencing this after importing MP3s). -John |
Putting here to help anyone with this same problem. Not a solution but a Avid knows about it and it's a bona fide PT bug...
Bug PT-271506 importing wav files results in corrupted audio white noise...happened to me when using Rogue Ameboa's Audio Hijack...(which I love for snagging audio from the computer). Workaround is to COVERT file on import rather than ADDing it to session. You can tick the PT preference box to convert import to the AES-31 standard. -or- Use Avid's suggestion "Import audio clip to Pro Tools>>Export audio clip from Pro Tools>>import newly exported audio clip to Pro Tools again." Entered on: 11/9/2022 5:00 PM Entered by: Manuel Christopher Entered on: 11/9/2022 5:26 PM Entered by: Customer
-John ProTools 2023.03 Avid Carbon/Firmware 1.23.10.4 A macOS Ventura13.2 MacBook Pro M2 Max, Mac14,6 96 GB |
Pro Tools 2022.6 with Avid Control 2022.4 | stargazer | Pro Tools | 2 | 07-01-2022 07:32 AM |
Is the MIDI zoom on the edit window broken in 2022.05 Windows? | snowplaysmusic | Pro Tools | 1 | 06-17-2022 06:44 PM |
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] | Dizzi45Z | Pro Tools | 43 | 05-29-2022 03:59 AM |
2022.4 Trackpad Zoom | gmu | Pro Tools | 0 | 05-16-2022 02:57 PM |
