Old 12-17-2007, 09:54 PM
yitbos yitbos is offline
Default problem assigning inputs
anyone else had this problem?
when we first installed the C24, everything worked fine (about three weeks ago). then, all of the sudden the C24 only lets us assign the ouputs of a MIDI track to one of the destinations we have installed. using the mouse, we have several destinations that we can get to, but the C24 only allows one. Then, tonight, the same thing started happening with our audio tracks, where we can only assign outputs to the interface, not to busses. again, using the mouse, we can assign anything no problem, it's only with the C24. anyone have any ideas?
thanks
Old 12-18-2007, 09:04 AM
livesoundguy livesoundguy is offline
Default Re: problem assigning inputs
You may need to go back a level in the navigation hierarchy of the C|24 to see all your options. You can do this by holding the Command/Ctrl modifier key and pressing the encoder switch for the channel.
For Example if you are assigning inputs and you have assigned:
Interface > Mic 1
To get back to the options of None/Interface/Bus, you would have to hold Command/Ctrl modifier key and press the encoder switch for the channel, then you will be taken up one level of the hierarchy.
Hope this helps.
Assigning inputs all at once instead of one by one remusjacobs macOS 6 09-27-2011 12:46 PM
8.1 Problem assigning outputs MX582 Pro Tools TDM Systems (Mac) 0 09-29-2010 02:20 PM
Strike - problem assigning outputs for multiple toms Che_Guitarra Virtual Instruments 6 06-21-2008 07:23 PM
Shortcut for assigning inputs broken?? Fireball71 Tips & Tricks 1 02-27-2006 09:30 PM
How about a quicker method for assigning inputs and outputs? scottlmicu Pro Tools TDM Systems (Mac) 8 09-03-2001 08:04 AM
