D-Command's Play button and Edit Menu problem
Somehow, when I hit the Play Button on the D-Command, it won't play but will light the Edit menu in blue on PT screen, as some command inside was being executed, triggered by a shortcut.
I first blamed QuicKeys so I shut it down. It was not it. Then I looked into the Undo history to see what was being executed. Nothing appeared, other than the expected. Play function works hitting the spacebar on the keyboard. I am running PTHD8.1.1 Does anyone have a clue on what it could be? Thanks! |
Re: D-Command's Play button and Edit Menu problem
Sounds like you have to trash PT preferences. I've had similar issues where I couldn't initiate recording from the console, but it worked from the keyboard. Stuff like that. Re-building PT prefs always fixes these weird things.
Great! It was that.
An other curious fact was that disabling the LTC (generate) button would solve the problem until enabling it back. Thanks! |
Music won't play. Play button flashes and Stop button lights up | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 04-16-2020 03:03 PM |
Problem with play button/Grid lines | SLN416 | Windows | 0 | 05-31-2011 12:11 PM |
Can't see my dropdown menu button in my edit window! | samhyman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-04-2009 05:31 PM |
Play Button Flashing Blue, edit cursor doesn't follow plybk | Steven Sauve | Pro Tools M-Powered (Mac) | 1 | 09-29-2007 10:08 AM |
Missing"Other" Button in Hardware Menu/5.0 | David Horner | Pro Tools TDM Systems (Mac) | 0 | 04-09-2000 11:54 AM |
