Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-04-2020, 04:24 PM
The Weed's Avatar
The Weed The Weed is online now
Default Multiple Inputs To One Aux Track...
Is it possible to have more than one input on an Aux Track? IIRC, you could have more than one output from a Track - and not Bus or Send - but don't recall if you can do this with inputs.
What I would like to do is have Line 1 and Line 6 come in on one Aux. Possible?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-04-2020, 04:35 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Multiple Inputs To One Aux Track...
You need to create a buss for it.
1, 2, 3, or however many tracks you want all have output of "thisismybuss" and then your aux has input of "thisismybuss".
But if you mean can it be done on the routing selection like multiple outputs, the answer is no. Any track whatever the type always has one input (or no input at all if all you want is stream your previously recorded audio).
Janne
sw rec sw rec is offline
No, but you should be able to do that with "sends" if I'm understanding you correctly.
Or you can change the output path on selected tracks to whatever the input is on your AUX track. Then everything will appear on the AUX fader. I do that with backup vocals, where there might be a large number of tracks, all the time. Works great for drum busses, too.
Old 04-05-2020, 10:21 AM
The Weed's Avatar
Thanks all, much appreciated. It was a question for Source-Connect usage within Pro Tools using the S-C Link plug-in. I wanted to use my talk-back mic and my VO mic, both going into the plug-in on separate inputs. I didn't think there was a way, but no harm in asking. I can just change the input to the Aux track, but will try sends when I get a chance.
Thanks again.
SonoBus
Old 04-06-2020, 12:14 PM
The Weed's Avatar
Thanks again, solved with Sends.
SonoBus
Multiple inputs assigned to a track? Bob Brown Pro Tools 2019 15 09-12-2023 06:33 AM
Soloing one track and an AUX with multiple pre-fader inputs HaendelGabriel Pro Tools | Intro Discussion 0 09-20-2017 07:06 AM
Multiple Inputs campsuck Pro Tools 11 2 12-22-2014 06:16 PM
Multiple mic inputs? desmondtencents Eleven Rack 7 11-12-2014 12:31 PM
multiple simultaneous inputs ether 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-18-2002 01:18 PM
