Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-04-2020, 10:49 AM
mdb mdb is offline
Default Pro Tools changes my language input settings (Windows)
So I've had shortcut trouble in the past where many shortcuts didn't work. I figured out the solution much later: I had to set my keyboard input to US English (was Dutch), and then the shortcuts started working.
I guess messing with the Windows system settings is "the Avid way" to fix problems. It now changes my language settings to ENG INTL all the time. I haven't even added this language input, and it does not show up in the language settings so I can't delete it either!
And you guessed it: Many shortcuts do NOT work with ENG INTL so I have to change it back all the time. It drives me NUTSSSSS....
I am on the verge of a total Windows image backup revert, to be sure things are as before upgrading. After 1 day of use.. Some Intel startup window has also disappeared after installing 2020.
What else is Pro Tools changing to my system settings? More than I ever want to know probably....
No input in IO settings. Pro tools 12 Charu1 Getting Started 10 07-18-2018 12:45 PM
Trouble with input source/keyboard language [SOLVED] marcelkavka macOS 2 11-05-2014 11:08 PM
Cannot switch input language/keyboard layout when I start PT as admin Kirby B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-02-2010 11:04 AM
How to change the language of pro tools 8 le GUI in windows XP??? long1211 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-15-2009 09:09 AM
