Re: ACID AND PRO TOOLS
I use SOHO to move ACID files (or any file) back and forth between my G4 and my PC. It's $50, you can buy it online from their website and since it uses NetBEUI you can still access the internet with your existing TCP/IP settings. Oh yeah, I connect them with a Netgear (DS104) hub. My broadband connection goes in the uplink port and the two boxes connect to 2 of the remaining ports. But if you use a dialup modem then I think you just leave the phone line connected to the PC or Mac. But if you have broadband in the uplink port they can share a connection...too much information. [img]images/icons/shocked.gif[/img]
Gerald |
i have a regular dial up isp and the computers will not necessarily be in the same room.......
do i have to have a network or email the files to myself? thanks again. [img]images/icons/rolleyes.gif[/img] |
i drop the files onto a zip disk and walk them over to my mac!
ok that makes sense......please excuse my ignorance..i am as tech minded as a bar napkin is the zip disk readable by both the mac and pc?
not having a zip disk on either box can i do this with a cd-rw without hassle? thanks again guys [img]images/icons/tongue.gif[/img] |
Yes, you can. You have to take care wich type of disk you burn....there are some incompatibilities. For example....dont use long names since the pc wont understand. Other then that: good solution, i use it to go from mac to pc and after some strugles its working great!
Bastiaan
What's that? - That's the machine that goes "pling". Bastiaan |
is there a certain brand of disk that will work better?
what "struggles" did you experience? thanks, j [img]images/icons/grin.gif[/img] |
ACID AND PRO TOOLS
i am a long time mac guy who is about to buy a second windows box for home. i am also going to mess with ACID on it.
what is the best way to take audio files from acid and drop them into a pro tools mac session? thanks in advance [img]images/icons/smile.gif[/img] |
Pro Tools and Acid Pro | justme420 | Virtual Instruments | 1 | 02-01-2010 06:59 PM |
ACID Pro and Pro Tools LE | SpencerC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 10-13-2004 04:22 PM |
Pro tools..Acid pro.. | Dogcode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-18-2004 07:00 PM |
using acid with pro tools le 5.1.1 | ira ostrowski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-25-2003 04:33 PM |
ACID Pro and Pro Tools | boutwell | Pro Tools TDM Systems (Mac) | 5 | 11-18-2001 03:57 AM |
