Old 12-15-2023, 04:36 PM
jeremiahmoore jeremiahmoore is offline
Default Newly Created Send Controls Fail to Isolate in Automation (are Un-Touchable)
Hi -- I've been battling this since at least PT2023.9, and it's definitely happening here in 2023.12. For all I know it's a known issue, but just in case.
-jeremiah
I use a pretty big mix template, but it's not uncommon to add some sends while mixing. I run into this issue a few times a week minimally.
Steps:
- Be working in a session with tracks in Latch mode *
- On some tracks: Create new sends.
- Touch controls on those newly created sends: If in Preview Mode, automation indicator on track should turn green, indicating preview active. Or: automation should start writing if in touch or latch. Instead it's as if though no automation is enabled for that control.
Screen-capture video demonstrating:
https://capture.dropbox.com/DcVHjofWBpFs26xb
Workaround:
Close and reopen session. Sends now automate as expected.
*might work in other automation modes, I've mainly only tried latch / preview, as that's how I work daily.
PT 2023.12 / MacOS 13.6.1 at present, tho have seen on various OS versions
Eucon: S3 + Dock + Control tablet
Old 12-15-2023, 05:07 PM
its2loud its2loud is offline
Default Re: Newly Created Send Controls Fail to Isolate in Automation (are Un-Touchable)
You’re in Trim mode. Check your preference for Include Sends in Trim Mode.
Under Preferences>Mixing>Automation>Include Sends in Trim Mode
Old 12-16-2023, 11:09 AM
No -
- Sends are not in trim mode. I've set the pref so sends are not included in trim
- Besides this: if they WERE in trim mode, they should also be writing automation breakpoints. Instead, the control does not pass touches to automation.
On another forum, someone suggested I try toggling the global automation enable for sends vol; will try soon as I'm back at my system
-j
Old 12-16-2023, 11:51 AM
maghikal maghikal is offline
The key is having "Include Sends in Trim Mode" disabled.
When that is enabled, this behavior does not crop up.
De/reactivating the entire track fixes it as well as toggling the S Vol automation enable in the Automation window.
Old 12-19-2023, 11:48 PM
To recharacterize this bug report:
For Sends created when track in Trim mode, Controls Fail to Isolate in Automation (are Un-Touchable) until Send Vol automation enable is toggled.
Steps to create:
- Set pref: sends not included in Trim*
- Set pref: automation latch prime in stop: on*
- On track(s): set automation mode to Latch Trim
- Create new sends
- Touch newly created send controls. Send Automation controls should be isolated or written, but are not.
* I'm unclear if these steps are required.
Workaround:
- When this occurs, toggle the global send volume automation enable in Automation window
- Alternately: disable and re-enable track(s)
- Alternately: close and re-open session
-jeremiah
HTML code is On
Automatically attention newly created track BigBadBill Avid S1, S3, Dock and Control App 1 11-12-2021 01:07 PM
One newly created track has gray wave and no sound sleeto Pro Tools | Intro Discussion 8 06-22-2021 02:02 AM
Predefined Inserts on Every Newly Created Track? Typhoon859 macOS 3 11-09-2013 02:48 AM
Can't open Pro Tools in a newly created user account ritaM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-31-2008 09:16 PM
newly created tracks defaulting to a certain out lagasus Pro Tools TDM Systems (Mac) 2 04-18-2002 12:29 AM
