OMF or AIFF?
When you're delivering a post mix to the producer, do you bounce it all down to a 2 track AIFF or give them back an OMF or is it pretty much case-by-case?
Also, if you're delivering an OMF, I guess you bounce it all out into a clean session (with all your plugs bounced, etc.) before exporting to OMF right?
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Mac Pro 8-core quad 2.26 24GB RAM Pro Tools 11 HDX Avid HDio 8Χ8 MBP Retina 3GHz Intel Core i7 8GB PT 11 Izotope Goodness NI Komplete Ultimate 10 NI Kontrol 61 Focal CMS 65's Sound Workshop 34-B Console '72 Fender Strat Fender Custom Shop Strat Bourgeois Slope D Mahogany/Bearclaw Nordstrand VJ5 |
Re: OMF or AIFF?
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
Re: OMF or AIFF?
BWAV
Ray Trujillo Freelance Audio Engineer |
Re: OMF or AIFF?
Is that what you get @ DCI?
I've done quite a bit with them (Silver Spring) and they've always been cool with split stereo AIFF.
Re: OMF or AIFF?
.. I meant interleave ;-)
Re: OMF or AIFF?
It's in the delivery specs.
Re: OMF or AIFF?
You must be referring to long-form stuff.
We just spit out promos which barely get QC'd at all.
Re: OMF or AIFF?
I deliver my promos as interleaved or mono .wav. I can only comment in what the global deliverable says. If your producer accepts .aiff that's cool. Is still PCM audio. But as an employee I have to refer you to the Global Delivery Specs.
Re: OMF or AIFF?
If its a simple stereo mix down, there is no need for OMF. Just give him an Interleaved Stereo file. Just make sure you talk to the picture departments first to verify how they want it to be synchronized, either with the Beep at 00:59:58:00 or to match audio file to picture length one.
__________________ Michael Goorevich Sound Designer/mixer https://converra.com/converter/mmf PT HD⎪N v2023.9 Ultimate ● macOS Ventura 13.6 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.6.9.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 Last edited by onridikpo; 12-06-2023 at 03:18 AM. |
Re: OMF or AIFF?
Not sure if this is you making another account, but there's an account that seems to be spoofing your credentials and copying your post. Might be wise to report that account, if it's not you.
Scott Gatteρo |
WAV and AIFF now SD II?? | MarkLancome | Pro Tools TDM Systems (Mac) | 0 | 10-25-2007 10:08 PM |
Bouncing to disk problems (wav, aiff-c, mp3, aiff) | TinglerFran | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-30-2003 11:38 PM |
Different AIFF ? | petter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-25-2002 08:31 AM |
SD2 vs. WAV vs. AIFF | audio_sti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-28-2001 03:24 PM |
AIFF to RMF | Tommytom | Pro Tools TDM Systems (Mac) | 1 | 05-09-2000 03:54 PM |
