4 Second delay after I press record and play, help!
After I press record and play it takes 4 seconds to start recording. It should record right away right? I don't know how to fix it. I don't think I touched any of the settings. Any help will be great. Thanks! |
Re: 4 Second delay after I press record and play, help!
Check your transport in the expanded view (with midi controls). There is a 2 bar count in that is probably highlighted. This baffled me once.
You need to post your system configuration for us to help you...
OS/PT Version/Hard Disks/etc... You aren't trying to record to a USB drive are you?
BRENT FREDERICK Musical Director, Arranger, Pianist PT10, MOTU Audio Express, 10.7.2 http://www.BrentFrederickMusic.com |
one of our G5 HD system is having the same problem with the small delay after hitting the space bar. I check the midi "2bar" thing and no change. Could a in compatable version of QT be the couplorate?
dual 1.8 G5 2.5 gig of RAM HD 1 accel DV picture PT 7.2cs2
Sound Editor Dual 2.0 G5 RevB 2 gigs of ram DVToolkit 2 PT 7.3 OS 10.4.8 |
Reduce the setting for Open Ended Record Allocation to 10 minutes.
Rail
what if this is happening in just play, not record?
What's your DAE Buffer setting? Rail
SOS Video Playback Problem 4 second delay when I press play | AudioPostChris | Post - Surround - Video | 7 | 01-19-2011 10:23 AM |
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
press record.... delay... delay...now it records | phanatik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-20-2007 03:20 PM |
I PRESS RECORD.. LONG DELAY BEFORE IT STARTS REC!! | sdre9090 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-16-2005 07:13 AM |
Getting tracks to line up when I press play on the MPC and record to PT6.1 | jon one | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-07-2003 04:53 PM |
