Re: Pro Tools 2023 and Mac Studio Ultra M2 graphic issues
HDX with 2 HDX cards in the Sonnox box and using Pro Tools ultimate. Right now I am not using the Hybrid engine for these 2 features I am working on. I will use the Hybrid in another film I am working on which has massive sound effects and design. I don't know if Hybrid is any better.
There are other issues not only with Pro Tools but with other plugins that are supposed to be Silicon ready. In Pro Tools I am finding a lot of buggy issues with Eucon (using artist control). For example, some of the artist soft keys on the artist screen will not light up when pressed, others will light up as expected. Eucon continues to disconnect, it has happened 4 times this week, where the Eucon connection green light turns red...oddly enough, when this happens some eucon functions still work..very strange. Is there a way I can upload Avid a screen recording of some of these issues? I cant be the only one seeing this. |
I'm running PT23.6 on a M1 MacStudio but no HDX.
At first I had major issues connecting 3 Monitors. I tried at least 5 different adapters and docks until I found a working USB-C to DVI adapter. I remember having graphic glitches as well and read somewhere to turn off the "Enable GPU" option in the PT preferences.
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78) LIO-8 BlackmagicDesign UltraMonitor3G Reaper 6.66, Fireface UCX MacbookPro M1Pro PTHD2021.12 MacOS12.1 BlackmagicDesign UltraMonitor3G MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB |
HDX, 2 cards in Sonnex Echo 3, with PT Ultra
I tried the enable GPU in the preferences both ways, no change.
I use 2 desktop 32" monitors. One is connected to the HDMI output of the Mac, the other I bought a USBc to HDMI cable adaptor ($20) and they both work. I see the graphic glitches on both screens, the HDMI and the USBc adaptor so I don't think is the computer. At the same time, I can play video on the film at 1920X1080 Pro Res on the same screens and that video is perfectly smooth, no issues at all. Audio is also not affected at all, no stuttering, or sync issues, nothing, is just the graphics in Pro Tools. I need to do a lot of trouble shooting, but I am too busy now, so I'll do it when I have time off (in my next life). My other monitors, the client large screen and my mini desktop viewer are connected to my Blackmagic Decklink card that resolved the system to video ref. |
I found the HDMI-32" was my issue with Graphic offset.
Switched main monitor to a TB3 to dual HDMI by Startech This is the Main display 32" 4K @ 2K Rez plus a 24" 1080 3rd Display 24" 1080 now off the built in HDMI (Go Figure) Mac Studio Ultra M1 Pro Tools HDX1 2023.6
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
I don't have any graphic 'sync issues' in any of my displays. My issues are graphic glitches. I am now running native on silicon and not via rosetta- I think I am seeing an improvement- the system is crazy fast However, I just started the new feature and will know know for sure for a while. I am using some very intensive CPU usage real time, look ahead, AI software and I am running 1% CPU. That plugin - one instance- would crash my 5,1 that had 128 RAM. I can now put 20 instances of that plugin (not that I need to) and not make a dent in the CPU...! There are still a lot of plugins that are not fully compatible with silicon, so these may be causing issues. I dumped Altiverb and Speakerphone until they make them 100% compatible. I am also trying to get an upgrade for my McDSP SA2 to run full silicon, otherwise Ill find another de-esser. Soundly also has a component that is not yet ready for silicon but I am told it will be available shortly. I am starting to think my issues are rosetta realted...not sure yet. |
I have an identical machine with a single HDX card. I flick between rosetta and silicon for plugins so have used both a lot. No real performance difference that I've noticed - but my sessions aren't enormous. It'll still stop playback when some plugins are loaded on track - even if it's the only track in the session - but that's the only error that occurs. Flawless otherwise. Only eucon problem (with S1's) is a fader occasionally forgets to kick in. Using two displays, thunderbolt-hdmi 4k and hdmi-hdmi 1080p. No problems with either.
Always possible the machine has an issue? |
The stream deck foot switch needs to be directly connected to a USB port, but works with the Active cable and there are no problems. Darryl is right though. USB hubs should ALWAYS be powered. Plug it in because it isn't drawing power from the computer. Don't forget Sonnet for docks either. I prefer this for my MBP. https://www.sonnetstore.com/collecti...olt4-hdmi-dock These USB hubs are very solid. No power supply hard wired to the hub. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 If you need an active USB extension https://www.amazon.com/CableCreation...93&sr=8-3&th=1 With this, there is no need for direct USB connection for iLok. I have 4 on my 2nd 13 port USB hub and they are fine. I have a 7 port in the closet with all my drives on it including a 4 drive USB OWC chassis with 4 SSDs in on one port. And 4 drives pulling from the hub. 3rd hub on my desk top in which I can plug in multiple SSD drives. But to do this, you will need to get a Dock. Everything works better when it has its own power, sans a single SSD drive. THIS, is important that Darryl points out. Quote:
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin |
Pro Tools 2023.3 with Mojave 10.14.6 Issues | wdjudd | Pro Tools | 8 | 12-30-2023 08:56 AM |
Pro Tools Studio 2023.6 freezes and cause force shutdown (not CPU issue) | antony.chourot | macOS | 8 | 08-16-2023 01:27 AM |
Pro Tools 2022.4 on Mac Studio M1 Ultra | Selle Sellink | Pro Tools | 47 | 06-05-2023 01:42 PM |
Pro Tools 2023.3 unstable while using VI's / MIDI Issues | ambitur3 | Pro Tools | 3 | 05-24-2023 03:48 PM |
Mac Studio _ Ultra OR MAX For Pro Tools/ plugins/VI’s ? | jepmus | Pro Tools HDX & HD Native Systems (Mac) | 10 | 04-05-2023 01:02 PM |
