  #201
Old 03-21-2022, 02:52 AM
BScout BScout is offline
Default Re: New "Mac Studio" from Apple
Originally Posted by TimNielsen View Post
If anyone has some other tests or something let me know.
Cool vid.
Notice you are running the internal sound card. What's the end game audio interface you are going to run with this? Have you tried it running that interface?
Also, any chance you can run one surround track with something intense like Cinematic Pro Surround reverb (I think that one scales to 7.1.2) filling all the insert slots? And then duplicating that track until it crashes? Reason for one track is because it forces all that to run in one thread since PT can't schedule it to other threads for a serial process. Probably make it an aux so you can feed it signal from some other audio track (even with white noise) to make the plugin(s) work.
And, oh yeah, have the fans audibly kicked in when stressing the system like this (including your buffer test)?
  #202
Old 03-21-2022, 03:40 AM
TimNielsen TimNielsen is offline
Ok In fact his turns out not to be that impressive as I thought as two friends on a 5.1 and hackentosh version can actually also play at 32 buffer with zero issues and no errors and actually lower CPU usage. So I guess in fact the Rosetta performance of PT pretty much does suck. 😊
  #203
Old 03-21-2022, 06:34 AM
Carl Lie Carl Lie is offline
Ok In fact his turns out not to be that impressive as I thought as two friends on a 5.1 and hackentosh version can actually also play at 32 buffer with zero issues and no errors and actually lower CPU usage. So I guess in fact the Rosetta performance of PT pretty much does suck. ��
Maybe performance enhancements come with soft synths and samplers or other ways than audio tracks (like loading times as mentioned). I saw a video with a Mac Studio where the presenter felt they were using much less power than Apple used in their comp charts for video performance. Hence why it's not totally kicking ass in that dept as described by Tim Cook.
I'm wondering if in order to make the next Mac Pro look super powerful these macs may be under powered. Or could simply be that certain plugs cause issues. Who knows...
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #204
Old 03-21-2022, 07:03 AM
James67 James67 is offline
Tim, would you mind to run an offline bounce of that Netflix session for about one minute and report the factor in brackets? I'd like to know that number in order to compare it to my Mac Pro 7,1. Thanks!
  #205
Old 03-21-2022, 07:32 AM
I think I've come to this conclusion:
IF your machine is going to be primarily a ProTools machine, this is not a worthy upgrade.
Some tests we all did yesterday, three systems. My Mac Studio Ultra, a Mac 5.1 2.6gHz machine, and a Mackintosh in PC hardware, all running the Netflix session. ALL of them played it fine at buffer 32, no errors or stops. All very smooth playback. And actually the Mac Studio faired the WORST for CPU usage, with it up in 80-90% on the meter (and my CPU meters in iStat would actually more or less confirm this). The Mac 5.1 CPU was around 80% and the Mackintosh more like 700-75%.
So all played it, all played it fine, but the Mac Studio was struggling MORE than the much older and cheaper machines.
This is clearly a limitation of non-native code running under emulation on Rosetta 2. Someday when Avid codes this, it will change.
But like me, I use this machine on various things, video work etc. So the improvement over my 5.1 is immense, even it for now ProTools doesn't drastically improve.
  #206
Old 03-21-2022, 11:38 AM
Eric Lambert's Avatar
Thanks for the thorough feedback, Tim!
Rosetta does seem to be creating more additional work than what is gained by the faster/newer machine, at least for ProTools.
As you mentioned, this will continue to improve over time as reliance upon Rosetta wanes.
I do wonder how others are getting along with more common sessions. The Netflix test is a solid sample of sessions similar to itself, but it's not real world for most people for most sessions. I also wonder what will happen when these machines are pushed to what we believe are their limits? Will they just continue to operate, with CPU metering which suggests capping, whereas older machines will actually choke and stutter?
  #207
Old 03-21-2022, 11:45 AM
But we don't buy computers to watch the Pro Tools CPU meters, which are clearly not always reflecting reality. What matters is can you run the session you want with stability, without CPU errors, with the plugins you want, and maybe the offline bounce speeds you want etc.
Focusing on what CPU meters are doing is likely the wrong angle to judge if these are good purchases now or not. If somebody has a struggling Mac and has been waiting for something new to move to this might well be it, even with Rosetta 2 and current lack of native Apple Silicon support. If you don't need to move now then don't but for folks on the edge the question is this a worthwhile upgrade now... and these Studio systems with a decent amount of memory for many users now look like they give an option.
(I don't have a Mac Studio and dont' need it now, I did test stuff on an early Apple silicon MBP).
  #208
Old 03-21-2022, 12:47 PM
ramonetl ramonetl is offline
I just got my Ultra on Friday, 128 gigs of ram, 2TB storage and 48 graphics cores. I'll share my initial thoughts.
Where did you manage to get a non base setup from so quick? everything around me says many weeks for extra disk etc.
  #209
Old 03-21-2022, 01:00 PM
kings79's Avatar
kings79 kings79 is offline
EXACTLY!
Well said.
Re-Recording Mixer/Sound Designer
Sydney Australia
OS Monterey
ProTools Ultimate 2022.4
Presonus Quantum 4848
Mac Studio M1 10 Core, 64gig RAM
Sonnet Echo dual NVMe TB Dock
Blackmagic Decklink 3G
  #210
Old 03-21-2022, 01:12 PM
caseystone caseystone is offline
That Sol Levante session won't play on my Trashcan at 32 buffer (will play at 64 though). And with video off even better, naturally.
I liked your previous answer better Tim! Argh... Apple Silicon Pro Tools now now now please!
Complete Recording Studio FOR SALE! Pro Toold Hd2 Accel, C24, Apple, Mogami, etc... sketchellis Buy & Sell 15 05-06-2013 06:27 PM
apple-m "mute region" clash with finder apple-m "minimize" wez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-12-2007 05:19 AM
2 Power-Mac's on 1 Apple Studio Display? Optimus Prime 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-02-2004 01:11 PM
Has anyone had this problem with their Apple Studio Display? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-29-2002 12:55 AM
Please advise on best setting on Apple Studio Display LCD Flatscreens - going blind! Jules Pro Tools TDM Systems (Mac) 5 05-05-2001 12:54 AM
