Old 06-02-2007, 06:41 AM
vdude vdude is offline
Default Pro Tools LE 7.3.1cs3 Update for Mac OS X Crashes PT
Pro Tools LE 7.3.1cs3 Update for Mac OS X installed on my G5 2.5 Quad, OS 10.3.8, DIGI 002. Now PT will not launch. Digi Coreaudio Driver will launch but when I click on the HW Setup button it crashes. Did all the usual permissions, Disk Warrior fix stuff including a full reinstall of PT7.3.1cs2. Still have the same problems. It seems as though it's something to do with permissions, PT software being unable to access files to get to the DIGI 002. Anyone know which file the DIGI CoreAudio Manager is trying to access when I click on the HW Setup button? Please help...
Old 06-02-2007, 07:32 AM
BFrederick BFrederick is offline
Default Re: Pro Tools LE 7.3.1cs3 Update for Mac OS X Crashes PT
Read the General Troubleshooting thread at the top of the LE forum. Do everything. Then, let us know if there is still a problem.
Good luck!
BRENT FREDERICK
Musical Director, Arranger, Pianist
PT10, MOTU Audio Express, 10.7.2
http://www.BrentFrederickMusic.com
Old 06-02-2007, 08:53 AM
So far working fine on the forbidden 10.4.9 here.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 06-02-2007, 11:19 AM
muzak13 muzak13 is offline
Did you repair permissions before and after installing. You should always do that with every piece of software.
peas
MacBook Pro DuoCore 17" 2.16Ghz • OSX 10.4.9 •*2Gb RAM • MBox 2 Pro • ProTools 7.3.1cs3 • FW 800 w/ Express Card
Old 06-03-2007, 10:17 AM
OK. I found my fix. Turns out it was a preference file. I created a new user and pro tools did open. So, I quickly narrowed it down to the invisible .GlobalPreferences.plist file in my user/Library/Preferences folder. Made a copy of this same file found in the new user Library/Preferences folder, changed the get info prefs to me. Put this copied file in my user/Library/Preferences folder and voila, Pro Tools opened. Only .Mac syncing and two other apps needed to be re-registered. And yes, I then installed ptle731cs3_36748.dmg a second time and all is well. I'm not sure, but I think some files in My user preference folder were bugged due to Kernel panics prior to installing this update. So, I avoided an Archive and install . Back to music making!
Old 06-03-2007, 12:02 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Digi says:
"Pro Tools LE 7.3 is officially supported on Mac OS X 10.4.8 for PowerPC-based and Intel-based Macs
Pro Tools 7.x will not run on Mac OS X 10.3.9 (Panther) and earlier."
You need to upgrade your OS to 10.4.8. 7.x is not supported on your 10.3.8.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-03-2007, 12:11 PM
bentropy bentropy is offline
This statement makes no sense. A.) you've mentioned the same version, but I assume this is a typo.
B.) Going from 10.4.9 to 10.4.8 isn't an upgrade. It's a downgrade. The problem is Digi, not their users. Digi needs to upgrade to the current OS, just like every music s/w manufacturer already has, rather than asking users – especially ones using Intel Core2 processors, which only work with 10.4.9 – to downgrade.
Digi says:
Old 06-03-2007, 12:52 PM
Slim Shady Slim Shady is offline
Um ben? Read more carefully. That's not what he was talking about at all and there is no typo in Park's post. 10.3.9 is different from 10.4.9, the original poster is using 10.3.8 which is why Park posted his suggestion.
And secondly, I've never seen it suggested to anyone that they downgrade if their machines come with 10.4.9. It seems to work for most folks, but for those on 10.4.8 it's recommended that they not upgrade in case they're one of the small percentage that has issues.
Old 06-03-2007, 01:03 PM
Ben, what are you talking about? This user is at 10.3.8 and 7.x is not supported. He needs to upgrade his OS for proper operation.
BTW, Waves says not to use 10.4.9 also.
Park
Old 06-03-2007, 05:23 PM
Correction : My original post at the top of this thread stated the wrong OS X operating system. I am actually running OS X 10.4.8 on a G5 2.5 PowerPC Quad , NOT 10.3.8 Too tired = Typos and mistakes. Thanks for your responses.
Pro Tools 7.3.1cs3 crashes on "Don't Save" process!!! M2E Pro Tools TDM Systems (Mac) 6 06-14-2007 05:14 PM
Pro Tools LE 7.3.1cs3 Update for Mac OS X Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-01-2007 05:13 PM
Pro Tools HD 7.3.1cs3 Update for Mac OS X Avid Pro Tools TDM Systems (Mac) 0 06-01-2007 05:02 PM
Pro Tools HD 7.1cs3 Update Avid Pro Tools TDM Systems (Win) 0 01-20-2006 07:05 PM
Pro Tools 6.4.1cs3 Update for MIX Systems Avid Pro Tools TDM Systems (Mac) 4 03-04-2005 12:47 PM
