Re: Ivory or NI Piano on a MacBook Pro?
Ready made multi-drive enclosures are available, though. I haven't (yet) had problems running BFD and Ivory (or any of my other sampled VI) samples from the same drive.
Thanks spkguitar! I agree about keeping the sound quality, ideally it would be good to get all this stuff fastened down to a something like a plank that you could drop in a keyboard bag or pedal board enclosure you could snap closed-grab the handle and go.
I was using BFD as an example of lower quality; setting the velocity layers to the highest value and running off the system drive causes frequent stops. To run them off the system drive I would have to decrease the velocity layers, thus decreasing the audio quality of the sample playback.
But the same applies to Ivory. I had a similar problem with Ivory when I first installed it on my PC laptop; samples were on the system drive and the only way I could use Ivory without hiccups was to set the voices lower than 24, which for some of the pieces that I work on is (for me) unacceptable (sustaining notes just disappearing because there aren't enough voices...), and/or set the buffer size to large which, depending on what else was in the session, would error out due to lack of available memory. Moving the samples to the external drive solved that problem for me. Due to that experience on the PC, I never installed it to the system drive of my mac (nor would I), and it's why I was/am recommending not doing so. The better/faster throughput of the external hard drive allows you change the settings in Ivory to get closer to a real Piano sound. This is not to say that Ivory doesn't still sound excellent when reducing the voices or using the default setting (because I think it sounds awesome no matter what), it just sounds more natural with the higher setting that the external drive allows.
spkguitar,thanks for your reply.
First, I should say that I'm using Ivory in a PT session with nothing else in it - no audio or other VI. I'm just playing - thinking about gigging with it. Haven't got around to recording yet. I usually record on my Mac Pro. I have a 2.0 Ghz macbook with 1 GB RAM. In this situation, with the samples on the macbooks HD, I am able to run the Bosendorfer 10 level with 24 voices, the release samples on and a TL space reverb. My buffer is small enough to allow instant sound. With all this, no hiccups, no notes stealing other notes. What I meant was it sounds so good I might have an accident if it sounded any better. I didn't mean that for technical reasons I know it can't sound better. But what extra awesomeness I could be missing out on? |
For gigging, I'd recommend using Ivory in its standalone mode. There is an updater on Synthogy's website. This way you don't have to worry about PT doing anything crazy during your gig.
Granted, you can't use the TL reverb this way, but Ivory has "Ambiance" on the effects page that should more than suffice for gigging. I find that I can get better performance out of Ivory in Standalone mode in terms of more voices before seeing "slow disk"... perhaps since the computer isn't shouldering another application with it.
BRENT FREDERICK Musical Director, Arranger, Pianist PT10, MOTU Audio Express, 10.7.2 http://www.BrentFrederickMusic.com |
Wow, I certainly will look into that! Thanks!
Thank you for that post, cheekypaul!!! The Pianoteq demo is blowing me away.
cool.
i didn't want to over sell it because it does have a unique sound. but i'm anti massive gigs of samples and i'm pro technology. let's go...
Mac Computers/PT12/Lots Of Lacie D2s |
Looking to purchase Synthogy's Ivory Grand Piano v1 | dbaldari85 | MIDI | 0 | 07-15-2011 04:14 PM |
Synthogy Ivory Piano 1.6 work with PT8? | Dynamixaled | Pro Tools TDM Systems (Mac) | 6 | 03-21-2010 01:50 PM |
Ivory or Akoustik Piano? | Jsswtpmp182 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-19-2007 01:19 AM |
looking for a Piano-Bar for a grand piano | teacherman | General Discussion | 2 | 01-09-2007 11:36 AM |
ivory piano and 6.9 | francois | Pro Tools TDM Systems (Mac) | 2 | 04-29-2005 08:36 PM |
