Old 11-21-2003, 04:32 PM
Yah Yah is offline
Default HELP HELP WITH PLUGIN SETTINGS
How do I save all my plugin settings at once with my session? ... Just had a mishap where my plugins settings changed when i open my mix on another system.I need help soon .....Dverb and compressor banks are the two main culprits here.
Thanks
One beat at a time.........
G4 , Dual Processor , 500mhz , 256 MB memory, 40 GB ATA 66 Hard Drive.
Old 11-21-2003, 06:53 PM
trakbytes trakbytes is offline
Default Re: HELP HELP WITH PLUGIN SETTINGS
In order to keep plug-in settings with a session, you have to automate them. Go to your plug-in, select the "auto" button, select everything in the left column and move it to the right column with the arrow button. You've now automation enabled all the parameters. Enable plug-in automation in the automation enable window.
Now, before you do anything else, go to the start of your session (or before the actual down-beat), put your automation in "Write" mode, and take a snapshot of the automation by pressing "command-option-/". This causes the automated parameters to snap to the current value at this point. If you want to save these settings for the entire session, go to automation enable window, and click the "write to end on stop" button. This will save current settings until the end of the session. You can also snapshot any change in settings at any point in the session. Snapshot only works if the channel is set to automation "write" mode.
If you just want to be able to recall settings for a different session, use the "Save settings" button in the plug-in window to be able to recall your favorite presets at any time.
rcm
Save early and often! (or once a day whether you need to or not...)
Old 11-21-2003, 06:58 PM
Tweakhead Tweakhead is offline
'Save Session Copy In..'
Select only the plug-in settings folder.
Old 11-21-2003, 08:12 PM
orage orage is offline
Inside your plug-in settings menu, there is an option (Preference?) that allows you designate where you can save plug-in settings...either in a root folder on the drive or within a folder called Session Plug-Ins that alongside the Fades and Audio folders in each session.
Use the latter, but you remember to save the settings for each plug-in to insure that they will travel with the session.
Hope this helps!
Paul Peterson
Sound Director
The Old Globe
San Diego, CA
Old 11-21-2003, 08:43 PM
Alécio Costa's Avatar
Alécio Costa Alécio Costa is offline
orage is right.also, when doing backups, with the SAVE SESSION COPY IN,do not forget to check the box save session plugs folder.
Alécio Costa Studio
High-End e-Mastering & Music Production
www.aleciocosta.com
http://www.facebook.com/alecio.costa
PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital
PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM
Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter.
Plugin Settings clancychris Pro Tools 9 0 11-12-2010 11:13 AM
Plugin Settings pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-12-2008 03:24 PM
plugin settings Brain Digger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-05-2005 03:52 PM
Hey, my plugin settings have gone away... blankpro Pro Tools TDM Systems (Mac) 4 01-27-2004 01:40 PM
Plugin settings Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2004 01:28 AM
