Monitoring Quicktime and PT
(since you can't rewire) What is a good way to monitor Quicktime and PT simultaneously -since they both can't access DAE at the same time. I would like them to both be open at the same time. (what about a pair of roland DM series monitors with the optical spdif inputs for monitoring the G5's built-in audio via optical port - analog port sounds too poor). If PT is using DAE and Quicktime is using built-in then both programs could be running at the same time and you could switch between them instantaneously and be able to hear both. Any comments would help.
Thanks, -c This is a followup to post titled "monitoring melodyne and pt" |
Re: Monitoring Quicktime and PT
1. Import Movie
2. Import Audio From Movie That will give you Quick Time in pro tools and you won't have to switch between aplications. |
rg,-c |
Direct Monitoring VS PT Monitoring | therecordinghouse | macOS | 5 | 11-23-2013 05:18 PM |
Quicktime monitoring settings | d.f. | Post - Surround - Video | 4 | 01-21-2011 01:26 PM |
Monitoring through Rosetta vs Monitoring through 003 | Rob0214 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-17-2010 03:02 AM |
Quicktime Crash on Export to Quicktime Movie | Yosemite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-28-2007 12:44 PM |
Major Problem Transfer TDM MAC Quicktime to PC Quicktime | audio1420 | Post - Surround - Video | 0 | 04-22-2003 09:41 PM |
