Recording regions a couple of samples late...
when I record, I get the regions late for a couple of samples. I always have to move them manualy.
do U all have the same problem or is it just me?! Please help, this thing is eating my nerves. PEACE
pardon my stinkin' writtin' |
Re: Recording regions a couple of samples late...
Are you using any RTAS effects? These can cause latency.
-Olaf |
What are you using to sample? What interface are you using?
[TheLP] |
if you have an mbox, latency is probably the cause, there is no real solution or way around it, but if you search this forum you'll find some good tips
2.0GHz Intel Core 2 Duo + 2GB RAM el-cheapo compusa generic firewire 80GB OSx 10.4.10, PTLE 7 (latest update) |
If you have a Mbox turn the mix knob all the may to input, then when you want to playback put it back to whatever setting you had.
[TheLP] |
BesnickB..I believe your speaking of recorded regions being a few samples late and not monitoring latency am I correct? There appears to be some confusion amongst the replies
Bazzle |
If you're worried about 2 samples.. then forget about it. Using busses in TDM has always had a 10 or so sample latency... most users ignore it.
Rail
stop looking at the screen and listen to the music, move something if it musically needs to be moved, not if the samples line up or not
I am having this problem when playing it, eventhough while singing it (recording it) everything is OK, but when the sound is captured, then it's late. Since I work mostly with rap music, it's really annoying.
No I don't have Mbox I have Digi002. Just to make everything clear here, I have the problem when playing it not just looking at it and it's not just a few samples but, say at a speed of 95 bpm the latency it's 1/16. Even if I use plugins (which here is not the case) I check for latency it shows 0 latency. PEACE
Recording timing / late recording issue resolved | DAWgEAR | Pro Tools HDX & HD Native Systems (Win) | 0 | 07-17-2013 09:10 AM |
PT9 win7x64 44 samples late recording | MikeLip | Pro Tools 9 | 0 | 11-07-2010 05:29 AM |
LE is tracking late(later than 164 samples) | macuser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-14-2005 12:13 AM |
Recorded Audio late by 3000 samples (MBOX) | melat3mg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-08-2004 09:01 AM |
